Just another Twelve Cylinder Wine Rack
Old Dec 22, 2013 | 02:03 PM
lickahotskillet's Avatar
Default Just another Twelve Cylinder Wine Rack
Couldn't sell it for cheap, and wouldn't give it away. There's no room in the house for a table, but there is room for a wine rack. Besides, I had to make room in the garage for a new arrival coming in February - 1960 Mark 2.
1) Distributor removal. Just had to save the new trigger, rotor, and vac retard.
2)One hammer test, two hammer test just to break the seal. Swings of the hammer got more violent as the block refused to give up the heads.
3)Archimedes is my friend.
4)Stud forest, careful your hands while removing with a pipe wrench
5)Piston Head, must be an Ohio thing.
6)Spares, ah nuts.
7)Wine rack ready for steaming.
Took the remains for a fitting end at the scrap yard. 670# of sheet steel (I added to the mix) and 170# of cast aluminum - mostly Jag.
Attached Thumbnails Just another Twelve Cylinder Wine Rack-img_0475.jpg   Just another Twelve Cylinder Wine Rack-img_0481.jpg   Just another Twelve Cylinder Wine Rack-img_0484.jpg   Just another Twelve Cylinder Wine Rack-img_0491.jpg   Just another Twelve Cylinder Wine Rack-img_0504.jpg
Just another Twelve Cylinder Wine Rack-img_0505.jpg   Just another Twelve Cylinder Wine Rack-img_0495.jpg
Old Dec 22, 2013 | 02:24 PM
Don't forget to let us see the finished article.
Old Dec 22, 2013 | 02:34 PM
Default Wine Rack
Wine Rack or the car? I be sure to show both.
Old Dec 22, 2013 | 04:30 PM
Wine rack, we want to see the car long before it's finished.
Old Dec 27, 2013 | 08:09 AM
Jtestrake's Avatar
It looks like you destroyed and scrapped the heads. That is unfortunate. Pre-HE flat heads are getting hard to find. I would have paid you for them if I had only known.
Old Dec 27, 2013 | 10:47 PM
Tried to off the engine and trans 2 & half years ago. Knew I risk someone wanting it after I trashed it. I'll do a better job of selling the parts off the mark 2 before I lump it.
Old Dec 28, 2013 | 01:33 AM
sherbercars's Avatar
Smile Hard luck
You could always use it for a Hard Luck Trophy.
Old Dec 28, 2013 | 01:42 AM
Gippsland's Avatar
And to think of how much love went into making that engine..
Old Dec 28, 2013 | 04:10 PM
Default Wine Rack
My friend and I discussed the "love of assembly" issue as we disassembled the beast. It was easy to see the racing heritage and the desire for smoothness. I knew I would find the remains of the chain tensioner, as it had jumped the distributor jack shaft in 2001. I let it sit for 8 or 9 years before I moved the distributor one tooth and fired it back up. By that time it was running on varnish.
Now the machine shop is razzing me for not having fired the BBC for the last 16 months. Goal for the road is the end of April 2014.
Regards,
Clyde Gantz
Old Aug 30, 2015 | 05:38 PM
Default Wine Rack Complete
Finally! Still need to shop for wine!
Hot washed, sand blasted, sprayed with adhesion promoter, then urethane cleared. Crank bobs and the main caps are painted with Glyptal. Coated the exposed rod journals with "Fluid Film".
Feet are made from some left over pieces of black walnut stair case spindles I used as legs on my bistro table.
Attached Thumbnails Just another Twelve Cylinder Wine Rack-img_2753.jpg   Just another Twelve Cylinder Wine Rack-img_2568.jpg   Just another Twelve Cylinder Wine Rack-img_2748.jpg   Just another Twelve Cylinder Wine Rack-img_2751.jpg   Just another Twelve Cylinder Wine Rack-img_2750.jpg
Old Aug 30, 2015 | 06:15 PM
amaezing's Avatar
I like it.. I like it alot.. If shipping wasn't going to kill me, I'd buy it.
That is an awesome way to recycle!!!!
Old Aug 30, 2015 | 07:22 PM
jagent's Avatar
Me too. Then I showed it to my wife and got the well practiced "as if" look.
Old Aug 30, 2015 | 07:29 PM
<p>I like that - very neat reuse!</p>
Old Aug 30, 2015 | 07:37 PM
Backyard Buddy's Avatar
Very nice!!!
Old Aug 30, 2015 | 07:38 PM
amaezing's Avatar
She gave me the thumbs. But then she's delt with me building motors in the front room.
Old Aug 30, 2015 | 08:34 PM
shipping and the price I'd want for it would scare us both.
Thanks all, for the great comments!
Old Aug 31, 2015 | 12:24 AM
Daf11e's Avatar
Very nice...well done.
Old Aug 31, 2015 | 10:48 AM
ronbros's Avatar
this would add the finishing touch, smoked glass table top, lay the block down and set it on top!
Attached Thumbnails Just another Twelve Cylinder Wine Rack-glass-top-smoked-brown-001.jpg
Old Aug 31, 2015 | 11:19 AM
Default glass top
I've see glass tops supported by pistons & rods. They look cool. Unfortunately, my house is too small.
As my girlfriend would say, "it's done, done".
Old Aug 31, 2015 | 12:47 PM
amaezing's Avatar
But then it wouldn't be a wine rack. It would be a nice table though.
