Is it just me???
Old Jul 22, 2017 | 11:37 AM
Darrenmb's Avatar
Veteran: Navy
Default Is it just me???
Or is anyone else nervous driving after a ride home on flat bed? I knew for a fact i had resolved the issue (see fuel pump question thread), yet still a bit gun shy merging into traffic etc!!! Its just a horrible feeling pushing down on the go pedal and nothing happening!!!
Old Jul 22, 2017 | 11:46 AM
JagCad's Avatar
Not one bit. AKA angst. But, most of us overcome it. Just "baby step" a bit
And work up to "jump in and go" state...
I'm on my way...
Or; When the horse throws you, climb right back on".
Done that literaly and figuratively!!!
Carl.
Old Jul 22, 2017 | 02:07 PM
Doug's Avatar
My Ford work truck has been randomly stalling and not restarting lately. Been on a tow truck 2x in the last month. My Honda has been overheating....but only on occasion. My Jag will stall from time-to-time for no readily apparent reason....although always restarts easily, thank god.
I'm a little nervous no matter what i drive these days !
Old Jul 22, 2017 | 05:59 PM
Jose's Avatar
not me, I drive a Ford van daily and it always starts, though I hate Ford air conditioners, it has been reliable.
the Jags too.
Old Jul 22, 2017 | 06:29 PM
For a while I felt like that because Nix would just STOP with No Warning!
First time was sort of out in the woods, but Flat Bed found us OK. I found the problem and fixed it *I Thought.* (that sucky Chevy HEI distributor cap arrangement, coil came loose)
Sometime later, same thing happened again! This time I was able to limp off the main road to a small side area, still in plain view, so Flat Bed easily found us again. Replaced another cap/coil combo.
About 3 months after that, we had to get a ride yet again!! By now I'm on first name basis with the driver and I can just hear everyone driving by thinking, "Jag! What a piece of junk!"
That time I was determined this Not happen again. The problem is, the screws provided to secure the coil into the cap are too short by about 2 threads, so they merely break out the holes with heat and engine vibration, coil looses ground, engine stops dead.
So I found some screws 2 threads longer, tightened them properly and haven't had a problem in over a year.
By now, after all the work and parts we've put into that car, it's as reliable as the 2009 Sonata and I jump in to go somewhere with about as much though of something will go wrong.
If you're sure you fixed it, just drive the thing! Worry takes all the fun out life; there's Quite enough unfun things these days to let something like this bother you.
Old Jul 22, 2017 | 06:43 PM
Doug's Avatar
Amen.
As a notorious worrier I can attest that 'worry' is a largely useless emotion.
Old Jul 23, 2017 | 12:38 AM
Rivguy's Avatar
Trust is a big issue. I would do some shake down running close to home in less stressful circumstances. After that just do it!
Old Jul 23, 2017 | 06:21 AM
o1xjr's Avatar
Mine failed to proceed today, and started again an hour later. I will do some investigating over the next couple of days.
But it won't stop me driving it, and I won't be nervous driving it. I know it is an old car with a lot of old wiring issues etc that may stop it at any time. You just deal with those situations as they come along.
At least this time it didn't catch fire and arrive home on a flatbed.
Old Jul 23, 2017 | 10:15 AM
JagCad's Avatar
Doug;
1. I can only remember the first part of an of "saw". "Ain't no use worrying.....". The rest is pessimistic. So, why?
2. I've gotten better at the worry avoidance thing. Over the years, I've realized that the "worry mountain" is much less than it seemed to be once confronted.
3. The Ford ignition module is much like the V12 unit It lives in the "V".
Pulling the distributor to swap it out involves other access restrictions. I've forgotten them. But, doable....
Relocation not so easy.
My 85 Ford had its only trip on a flat bed, because of a failed module...
Carl
