Lowering front end on XJ6C
Old Nov 14, 2019 | 04:11 PM
jshedd00's Avatar
Default Lowering front end on XJ6C
I want to drop my front end a few inches. Any aftermarket front coils that are shorter for this car?
Old Nov 14, 2019 | 11:54 PM
JaguarSpecialties's Avatar
Former Sponsor
Take a look at King Springs on Ebay Australia. Not cheap, but they have a lower set (front or rear)....
Old Nov 15, 2019 | 06:44 AM
Yellow series3's Avatar
Beautiful car, and yes, assuming the wheels are the same size, the nose looks several inches high. Is it due to a lighter v8 engine?
Old Nov 15, 2019 | 08:38 AM
jshedd00's Avatar
Yes, V8 swap. But those are 18” rims not the 15” that was original. Just lower profile tires to compensate.
interested in options to lower that nose.
Old Nov 15, 2019 | 09:20 AM
jshedd00's Avatar
Thanks.. I will look into King Springs..
Old Nov 15, 2019 | 01:38 PM
icsamerica's Avatar
King Springs or not you can still dial in the height with pan spacers.
This Thread might shine some light. I have used aluminum and steel spacers. Both are fine but I prefer steel.
https://www.jaguarforums.com/forum/x...ng-pan-199734/
Old Nov 15, 2019 | 02:04 PM
jshedd00's Avatar
Very good Thread suggestion. Good advice from some that have had success. Thank you.
Old Nov 15, 2019 | 04:42 PM
ronbros's Avatar
i lowered my front on XJS , used steel spacers and it is surprising how much 1/4" inch made lower!
but it also raised the rear up about the same amount,maybe more , XJS has a lot of over hang on rear!
it seemed to pivot from the rear wheel centers!
ron
Old Nov 15, 2019 | 04:57 PM
sanchez's Avatar
When I did my Chevy conversion I had the same problem.
I resolved the issue by removing the spacers from the coil spring (2 on each side) and 1 1/16 grade 8 washers at the spring pan.
From this
to this
spring spacers
Old Nov 15, 2019 | 10:24 PM
icsamerica's Avatar
The XJ40 wheel looks great, seats look inviting. I prefer a wood dash though. Is that dash treatment a sticker?
Old Nov 15, 2019 | 10:29 PM
Crackerbuzz's Avatar
Jshed, Was this originally a 4.2 litre that you V8 swapped?
What engine are you running now?
If so, I though she would have dropped more than this on the front???
Old Nov 16, 2019 | 08:15 AM
jshedd00's Avatar
Thanks Sanchez. I think that is where I will start.
Old Nov 16, 2019 | 08:18 AM
jshedd00's Avatar
Yes, 4.2 for V8. I was also surprised at the weight difference.
Old Nov 16, 2019 | 08:22 AM
jshedd00's Avatar
Carbon fiber wrap on dash. I wanted something brighter than the dark gauges and brown dash.
Old Nov 16, 2019 | 03:42 PM
Is this a carburetted 350?
What tranny are you running?
Old Dec 26, 2019 | 12:26 AM
Fatbug57's Avatar
From this
to this
spring spacers
So Sanchez, you just took out the upper spacers and then added the washers to the spring plates to lower the plate a little? The reason I am asking is I will be doing this to the 1974 car I just got because it has had the 350 swap done and sits high in the front. Please let me know and thanks.
Old Dec 26, 2019 | 05:04 AM
sanchez's Avatar
Yes. I resolved the issue by removing the spacers from the coil spring (2 on each side) and 1 1/16 grade 8 washers at the spring pan.
After driving the car around for a couple of months, the springs settled and I removed the grade 8 washers I had added at the spring pan.
You will have to design a tool to remove the coil springs from the car.
front spring removal tool
Old Dec 26, 2019 | 06:56 AM
jshedd00's Avatar
Used a local restoration shop, they had a process to slowly heat the springs to lower.
2” front drop
Old Dec 30, 2019 | 08:05 PM
Jahmiata's Avatar
Wow, beautiful car!!!!
Old Dec 31, 2019 | 05:22 AM
sanchez's Avatar
Is the ride still as smooth using the heat treatment method to lower the front?
Regardless, the stance looks great and so is your car.
