Micro Switcher
Old Jun 3, 2015 | 12:50 AM
adenshillito's Avatar
Default Micro Switcher
Hi, just replaced a micro switch just above the mass air metre, think it works the throttle? the base terminal is a command terminal and it has two other terminals for 'always on' and 'always off'
which position should this be set for? on or off?
Old Jun 3, 2015 | 08:27 AM
Doug's Avatar
That looks like the enrichment switch mounted at the throttle body.
My guess....hopefully others will chime in....is that is should be 'always off' until the throttle is opened wide....at which points it turns 'on'. So, use the terminal marked 'normally open' or 'NO'.
kevinl
Oct 31, 2019 06:15 PM
jagosaurus
Mar 11, 2016 08:41 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Johnken
Sep 15, 2015 05:46 PM
