newbe help
Old Oct 7, 2012 | 05:25 PM
  #121
tudstuen's Avatar
Default thinking its the ecu
what do you think
Old Oct 7, 2012 | 05:51 PM
  #122
Jose's Avatar
Originally Posted by tudstuen
has power ...thanks Jose
still no start? have you removed and replaced the ignition cap at some point?
Old Oct 7, 2012 | 06:07 PM
  #123
Jose's Avatar
here's two better ECU and fuel injection component diagrams that you might want to have blown up poster size at Office Depot: also do some reading at this page:
http://en.allexperts.com/q/Jaguar-Re...g-XJ6-dies.htm
Old Oct 7, 2012 | 07:43 PM
  #124
tudstuen's Avatar
Default still no start
what do you meen by ignition cap?
Old Oct 7, 2012 | 07:44 PM
  #125
tudstuen's Avatar
Default oh distributer cap
yes new and new roter and plugs and wires
Old Oct 7, 2012 | 08:06 PM
  #126
Jose's Avatar
the distributor cap, where all the 7 plug and coil wires connect to the distributor.
is yours the type bolted with two screws?
are you 100% sure it is seated correctly? (even though the distributor has been mostly eliminated by now as the cause of the no-start).
Old Oct 7, 2012 | 09:12 PM
  #127
tudstuen's Avatar
Default dis cap
yes 2 screws ,, im sure it is ,,but ill check again
Old Oct 7, 2012 | 09:13 PM
  #128
tudstuen's Avatar
Default ecu from a 88
by chance would a ecu from a 88 work.. im thinking not since ser 3 ends in 87 doesnt?
Old Oct 7, 2012 | 09:19 PM
  #129
Doug's Avatar
Yeah, not related to lack of injector pulse.
Upstream, at the primary side of the system, a faulty module might relate to lack of injector pulse...as the ECU relies on a trigger pulse from the negative side of the coil. But, since we have spark, I think we can safely eliminate the module
Old Oct 7, 2012 | 09:22 PM
  #130
Doug's Avatar
Right. Ser III XJ6 ended in April 1987 as a 1987 model. The V12 versions carried on until 1992 but that's neither here nor there
A 1988 ECU will not work.
Contact David Boger at EverydayXJ. Great source for used Ser III parts.
Old Oct 8, 2012 | 05:48 AM
  #131
Jose's Avatar
I still think something may be either disconnected, or incorrectly re-connected.
Old Oct 8, 2012 | 09:04 AM
  #132
tudstuen's Avatar
Default Ecu?
After all we have investigated is it the ECU..? again there is power to the ecu at brown/slate wire.
Old Oct 8, 2012 | 09:12 AM
  #133
Jose's Avatar
I refuse to conclude it is the ECU, but I'm not there to use my incredible Trial-n-Error Nician skills.
Old Oct 8, 2012 | 10:43 AM
  #134
Doug's Avatar
I've about run out of ideas.
I'm ready to say "ECU" or "Injector Resistor pack". Both have low failure history, though, so it pains me a bit to suggest either. Not sure how to DIY bench test the resistor pack and I don't think there is any way at all to DIY test the ECU...except by substitution.
On the bright side neither should be very expensive used so, as guesses go, it won't be too painful.
Old Oct 8, 2012 | 04:08 PM
  #135
tudstuen's Avatar
Default ok thanks
im going to see if Frank has and can send the resister pack. theres a few desent ecu's on enbay as well for not alot$$
Old Oct 8, 2012 | 07:41 PM
  #136
denraden1's Avatar
Tudstuen: I have the Injector resistor pack, ECU and diode pac for a 1984 XJ6. AFAIK they are all in good working condition.
Old Oct 8, 2012 | 08:22 PM
  #137
tudstuen's Avatar
Default ill take them all
i emailed you back when is a good time to call
Old Oct 14, 2012 | 04:12 PM
  #138
tudstuen's Avatar
Default seats
will seats from a 96 xj6 bolt up to the 86?
Old Oct 14, 2012 | 05:05 PM
  #139
Jose's Avatar
I've never tried it, but did you get the engine started?
Old Oct 14, 2012 | 07:07 PM
  #140
tudstuen's Avatar
Default start
havent got the parts yet was suppose to get them yesterday but the guy couldnt meet me.. hopefully tomorrow..ill post what happens
