newbe help
Old Oct 15, 2012 | 01:24 PM
  #141
tudstuen's Avatar
Default guess what
replaced ecu,resister pack and diode.
1.1st did reister pack ,,, nothing
2.then did diode. nothing
3. then did ecu and nothing
checked injectors and now I do have a blinking light when cracked but still nothing like before not even a almost start
all were warrantied.. in working order from a good supply source
Old Oct 15, 2012 | 01:31 PM
  #142
tudstuen's Avatar
Default coil neg post
is it possible for the neg post were you tighten the nuts be bad???
my son did away with that little ballast thing thing lie Jose said.. but i think he over tightened it and the nuts wont tighten like they should ..its tight but like the nut was crosstreaded and it only snug.. could that have damaged the neg post screw therefore make for a no start. just a idea cuz im out of ideas
Old Oct 15, 2012 | 01:51 PM
  #143
Jose's Avatar
do you mean the nuts and post on the Coil?
obviously not an issue of the ECU. those rarely go bad.
another dumb question, but does the engine turn when you crank the ignition switch?
A) have you double checked the Inertia Fuel Cutoff switch?
is the button on top of the IFCS springy when you press it down? (in other words, it does not click when pressed). (think of it as a "Reset" button).
This switch can disable the car totally. Check it again and again.
B) if the fuel pump was replaced, can you hear it whirring with the shifter in 1st gear and turning the ignition switch to START?
C) no gasoline leaking anywhere?
Old Oct 15, 2012 | 01:59 PM
  #144
tudstuen's Avatar
Default maybe on to something
yes to nuts on the neg post of coil
yes it cranks
the fuel pump whirls
no gas leak
but the IFCS is not springy.. i checked it alot but only by pulling it up to show red..it was not up in the red area.. if you pull it up no spring and it just falls down when touched and no click at all
Old Oct 15, 2012 | 03:24 PM
  #145
tudstuen's Avatar
Default ifcs
how does it work.. should it be down when in safe mode and up showing red when its not in safe mode.. if i pull it up to show red the fuel doenst flow.. i dont feel a spring but if you pull it up it stays red until you touch it and it falls back down.. im thinking its working ok by this ..or im i wrong
Old Oct 15, 2012 | 03:40 PM
  #146
Jose's Avatar
the IFCS tripps (like a house breaker), if the car flips or during a heavy crash.
Red up means tripped. It should "click" when you press it down if in Red, meaning it has reset, like a reset button in a vacuum cleaner when it overheats?
don't know what to tell you, the only way would be for someone to press it down to see if there is fuel flow to the engine, OR, if you have already verified there IS fuel flow to the engine, then it must be ok, not tripped.
sometimes it's the silly things that disable a car, I'm just looking for the not-so-obvious.
is the coil post moving when you tighten the nut?
Old Oct 15, 2012 | 03:58 PM
  #147
tudstuen's Avatar
Default theres fuel 36 psi
the coil post doesnt move just wondered.. the only thing i havent changed is the start relay......what about the timing chain or belt///wouldnt i get the same thing
Old Oct 15, 2012 | 04:11 PM
  #148
Jose's Avatar
try to re-thread the post, shouldn't be too difficult. the only way to really test the start relay is by substitution. Leave the timing chain/belt alone for now.
Old Oct 15, 2012 | 04:12 PM
  #149
tudstuen's Avatar
Default it does not click
when i press it down............does it only shut off fuel like a plunger. or is there a electrical thing that wont let it start
Old Oct 15, 2012 | 05:30 PM
  #150
tudstuen's Avatar
Default afm
anyone have a diagram of the pins that go into the afm
Old Oct 15, 2012 | 06:18 PM
  #151
Jose's Avatar
when you press it down, it allows the fuel pump to pump and pressurize the fuel system, it works electrically by shutting the fuel pump off, so when it tripps, there's no fuel pressure.
Old Oct 15, 2012 | 06:19 PM
  #152
Jose's Avatar
you mean the serial plug ?
Old Oct 15, 2012 | 06:28 PM
  #153
tudstuen's Avatar
Default no
the start ifcs
Old Oct 15, 2012 | 07:20 PM
  #154
Doug's Avatar
If there's any doubt about the inertia switch just unplug the wires and join 'em together.
Old Oct 15, 2012 | 08:40 PM
  #155
tudstuen's Avatar
Default inertia switch
what do you mean by join together.........also if the switch is faulty wouldn't it shut fuel down
Old Oct 15, 2012 | 08:55 PM
  #156
Doug's Avatar
Use a jumper wire or whatever to join them together, bypassing the switch to get it out of the picture, although........
Yes, and as I recall you DO have fuel pressure....so one way or another the fuel pump is working.
Old Oct 15, 2012 | 08:58 PM
  #157
Doug's Avatar
The diagrams from the S57 Electrical Guide (which I think you have and are on the Captain Jaguar electrical reference page) show the terminal numbers and wire colrs. That's probably as good as it gets
Old Oct 16, 2012 | 10:53 AM
  #158
tudstuen's Avatar
Default new idea
just a thought,, but since now the noid light flickers when cranked is it possible all the injectors crapped out or most
Old Oct 16, 2012 | 11:08 AM
  #159
Doug's Avatar
At this point I'm willing to say anything is possible. You could pull the fuel rail with injectors attached and actually see if they squirt fuel
Old Oct 16, 2012 | 03:44 PM
  #160
Fraser Mitchell's Avatar
Now 158 posts on this thread ! Don't you think a purchase of the Series 3 Workshop Manual might be a good idea !
