Overheating series 3
Old Apr 22, 2009 | 10:20 AM
Walter1982's Avatar
Default Overheating series 3
My 82 XJ6 temp is at 130+. I live in Phoenix and it is just starting to get hot down here. How can I keep my cat cool?
Old Apr 22, 2009 | 10:53 AM
dave2's Avatar
There are three parts to this puzzle, radiator, thermostat, and fan.
I would put my money on the thermostat being stuck closed to be getting temps like that. I have seen my engine hit 100 but never 130, that was 98F weather with AC on full, idling in traffic.
Thermostat is easy to get to on these cars, the bolts that retain it unfortunately are not easy to get out. They have been known to strip and snap, so be prepared.
Secondly, I would recommend flushing out the radiator/engine block to get all sludge out. Sludge will increase temps.
Fan, verify that the thermal clutch works by trying to rotate the fan by hand, it should spin maybe 1/2 turn.
A good cooling system will keep the engine to 82C +- a couple of degrees in any weather. If you are having issues with the cooling system, it is best to really give it a good going over, flushing it all out and popping a new thermostat in, refilling it with nice clean fluid.
Old Apr 22, 2009 | 03:44 PM
Walter1982's Avatar
how do i flush the system? shall I remove the radiator and get the junk out or leave it in the car? just put a hose on it?
Old Apr 22, 2009 | 11:42 PM
JagtechOhio's Avatar
That's a whole bunch of excellent advice, with one point to add:
The auxilliary cooling fan on the original poster's car should also be running, and on early 1982 there are two of them. Normally they will not kick on unless there is a pre-existing cooling system fault that is allowing the temp to exceed normal limits: so it's not the cause of his overheating, but is another problem to sort out if it hasn't been coming on at 100 C. It will be needed when running the car with A/C on in the desert heat, that's what it's on the car for.
Old Apr 23, 2009 | 06:34 AM
Keith's Avatar
Also, Barrs leak was used regularly and recommended by Jaguar, so you may have a ton of it in the radiator. If your going to take the radiator out anyway, let a radiator shop check it out, or reinstall a new one, as suggested, certainly can't hurt, and, you'll probably have to anyway sometime in the future.
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
k-man
Oct 5, 2015 08:09 AM
