Pabst Blue Ribbon meets Tea and Crumpets
Old Mar 5, 2018 | 08:51 PM
  #181
sunchip's Avatar
thats a good idea, ill see how much room i have to play with and then see what i can do to make it stronger.
Old Mar 9, 2018 | 09:21 PM
  #182
sunchip's Avatar
tomorrow i take on the task of redoing my exhaust from the headers back. Is 4 flanged joints too many? im planning on having a 2 bolt flange from the headers to the y pipe, a 2 bolt flange from the y pipe to the int pipe and a bolt flange at the muffler
Old Mar 11, 2018 | 10:41 AM
  #183
lickahotskillet's Avatar
Used three bolt flanges and copper gaskets on my '77 - 3 each side. They leak a little, but with the Super 44's you can't tell.
Putting "V" band clamps on the '60 - 4 per side and one in the center of the "H" pipe. (Yonaka, $25 each - out of Canada - they up graded the "T" bolts with no price increase. ) '60 is still under construction.
Old Mar 12, 2018 | 06:57 PM
  #184
Rustyxjc's Avatar
How are the Manual brakes working out?
Rusty
Old Mar 12, 2018 | 09:08 PM
  #185
sunchip's Avatar
i havent checked on v band flanges but im guessing they would be more than the 2.29 i paid for each 2 bolt flange, im not worried about the flanges leaking im going to sand them perfectly flat and use copper spray to make sure of a good seal. but from the replies having multiple flanges should be a problem then. I thought about making the whole thing one unit but that would be a headache to get out if i needed too.
and for the brakes im not sure. they look good but i wont know how they feel for a bit. need to get a few other things tidied up before i put fluid in them and test them out
Old Mar 13, 2018 | 11:06 AM
  #186
Default three bolt flange & V band
Sunchip,
Flange system is for '77XJ12L. 2 1/2" goes under differential.
"V Band" system is on a 1960 Jaguar MK2.
Compared to $2.19, $25 per clamp may seem expensive. The Yonaka's have a interlocking flange. A certain racing company's least expensive offer starts at $30 without and interlocking flange, then you move to $80 or so for the real pretty ones.
Attached Thumbnails Pabst Blue Ribbon meets Tea and Crumpets-exhaust-system-view-rear-floor.jpg   Pabst Blue Ribbon meets Tea and Crumpets-img_1306.jpg   Pabst Blue Ribbon meets Tea and Crumpets-img_4217.jpg   Pabst Blue Ribbon meets Tea and Crumpets-img_4394.jpg
Old Apr 5, 2018 | 09:53 PM
  #187
sunchip's Avatar
so the old saying "do it properly and you wont have to do it again" is really coming to light this year. So many things i did last year are needing to be replaced are changed. The exhaust was held together, with lets be honest, hopes and dreams. No matter thats being sorted with a properly flanged system. The suspension modifications are being corrected and improved upon, better end links and shock mounts. The cheap shifter is being replaced with a lokar unit. The cheap steering wheel is being replaced with a momo unit.
Once i get the exhaust and shifter fitted then there isnt much stoping me from getting this thing on the road.
that being said, does anyone have a write up how to disassemble and reassemble the doors? Im going to use dorman window switches and i have my painless wiring kit but the actual R&R of the door would be useful to read over before i get into it
Old Apr 9, 2018 | 09:31 PM
  #188
sunchip's Avatar
well here it is. looks half decent, and for less than 300$ total for 2 cats, pipes, resonator and muffler, im pretty pleased
Old Apr 9, 2018 | 10:13 PM
  #189
Rustyxjc's Avatar
Looks Nice! How does it sound?
Rusty
Old Nov 10, 2018 | 01:18 PM
  #190
sunchip's Avatar
Rusty
Unfortunately i have no idea still. Been dealing with constant carb issues and timing problems... Im thinking about just towing the car to a tuner when its nice out again here...
Old Jan 23, 2020 | 02:27 PM
  #191
sunchip's Avatar
Hello again everyone on the forums!
After a looooooooong hiatus I will hopefully be diving back into this project with some new goals for the coming years.
Main goal is converting the car to all electric. I'm still researching how to go about this and will update here from time to time.
Hope all is well with everyone here and their cats!
Old Jan 24, 2020 | 07:54 AM
  #192
icsamerica's Avatar
Electric? Well there's a twist. Been thinking about an Electric Porsche 928 myself....but to build what I want will cost 20k and hard to rationalize that but I hope battery prices will drop soon.
Old Feb 25, 2020 | 10:32 PM
  #193
Bry5on's Avatar
XJ is not a great starting point for an electric conversion, but if you're honestly interested the easiest route is to get a transmission from a lexus GS450H, lock the input shaft, and drive both motors inside the transmission to turn the output shaft.
Good luck!
Old Aug 28, 2023 | 02:30 PM
  #194
sunchip's Avatar
So I've been MIA for a while now but figured it was time to post an update.
Car is for sale. Best offer takes it. If its not sold by mid September itll be up on BringATrailer and then sold there.
End of an era, but a move to Europe means the toys get sold.
Old Aug 28, 2023 | 09:21 PM
  #195
Life moves on, doesn't it.
I wish you success in your next life.
richzak
Oct 16, 2015 03:48 AM
doc
Oct 13, 2015 09:16 PM
JagBrian
Oct 1, 2015 12:52 AM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
