Picture of door hinge with wing removed on S3
Old Apr 17, 2020 | 07:53 PM
iramphal's Avatar
Default Picture of door hinge with wing removed on S3
Anyone have a picture of the front door hinge attachment with the front wing removed? Specifically, does removing the wing help in adjusting the door hinges?
Old Apr 19, 2020 | 06:59 PM
Larry Louton's Avatar
Assuming that you are working on the left Front door, Turn the steering wheel hard to the left to access a panel just forward of the door hinges but on the inside of the fender. Remove this panel and two bolts that go downward behind the fender. You can now pull out the fender a bit to access the lower hinge bolts that go into the body, If that is not enough, There is two more fender bolts just above the lower hinge going into the body. There is a big chance of clash between the door and the fender. Be careful and good luck.
Erik van Harten
XF (X260)
Aug 17, 2019 11:31 AM
BobRoy
Aug 5, 2018 07:03 PM
paintbysimon
Aug 23, 2016 02:06 PM
leep123
Jul 25, 2015 06:22 AM
wesmc
Feb 9, 2015 05:54 PM
