Rear window defroster inoperative
Old Oct 16, 2015 | 05:45 PM
ahunt4's Avatar
Default Rear window defroster inoperative
1982 series 3
Can someone give me a sort of checklist to check the rear defroster?
When I hit the switch the light on the dash comes on but there is nothing going on in the back and no heat
Old Oct 17, 2015 | 12:54 AM
Doug's Avatar
If you have a test light or meter you can check for voltage at the plug to the defroster grid. There are actually two plugs, left and right. One gets 12 volts, the other goes to ground. I can't remember which is which. But, if neither gets 12volts with the switch on, post back.
If you DO get 12 volts at the grid plug then you've probably lost the ground. Might be as simple as the wire being disconnected.
VinnyT
Jan 25, 2016 07:46 PM
b1mcp
Jan 25, 2016 04:23 AM
NTL1991
Oct 28, 2015 10:32 AM
jagnation89
Oct 17, 2015 01:48 PM
randyb
Oct 13, 2015 10:48 PM
