Rear Windsheild
Old Apr 4, 2009 | 11:35 PM
wayne1991's Avatar
Default Rear Windsheild
is there any trim you have to remove before you can pull the rear windsheild out of a 1985 jaguar xj6
Old Apr 5, 2009 | 05:56 PM
Jose's Avatar
on the outside, carefully pry the chrome edging crimped on the rubber seal itself.
in the interior, I would remove the rear seat belt reels, then the parcel shelf cover complete with ventilator, then the side foam-headliner pieces on the C pillars, then the bottom metal piece covered in headliner material running left to right, and then I would fold and insert a piece of cardboard under the entire top rear edge of the headliner, chances are it will get stained by the silicone goo if you don't protect it.
Jose
Old Apr 6, 2009 | 07:43 PM
wayne1991's Avatar
i took off everything needed but i dont know how to get the parcel cover or whatever it is called off. How do you take it off?
Old Apr 7, 2009 | 04:58 AM
Jose's Avatar
you have to remove the rear seat first, (2 screws, front bottom) and then the rear seat Back or "squab". (another 2 screws on bottom). you don't want anyone pushing down on the leather with their knees, a recipe for damage.
Then it becomes obvious, assuming the two Seat Belt take-up reels are off. You might have to get on your back in the trunk, removing the "hardura" covering at the very back and top of the parcel shelf viewing it from the trunk.
Old Apr 7, 2009 | 04:55 PM
wayne1991's Avatar
Thanks Jose, you are the best help on the forum.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
jdzubas
Oct 4, 2015 09:14 AM
Quebecjag
Sep 10, 2015 06:06 AM
AtholC
Sep 9, 2015 09:07 PM
