Relais question series 1
Old Oct 10, 2016 | 01:00 PM
XJeej's Avatar
Default Relais question series 1
Hello all, I bought a Jag for €200 with no engine and dashboard. I swapped the dashboard over but I got confused by the relais on top of the dash. Does anybody know what these 3 relais are for?
Relais on top of dash
Left side relais
Relais right side
Old Oct 13, 2016 | 03:47 PM
Japawels's Avatar
The one mounted on the dashboard is, as I recall, main ignition relay. The other two I haven't seen on my car, but I would guess they might be for electric windows. That is of course if yours are electric.
I can check with the manual tomorrow when I get to the garage and let you know.
Old Oct 14, 2016 | 03:26 AM
XJeej's Avatar
Would be very much appreciated! I've worked out the one on the left tics on when I turn the key. I suspect it may be the wiper relay on top of the dash.
Old Oct 15, 2016 | 05:53 AM
Japawels's Avatar
This is the only information about relays that the manual mentions. It seems that the one on the left-hand screen pillar is an alternator relay. On the opposite side should be a starter solenoid switch relay. (pic related)
I couldn't find any info on the third one, but as I mentioned I remember it to be a main ignition relay also referred to as a "ignition protection relay".
Hope it helps, if you're interested I can send you also a full wiring diagram from the service manual.
Attached Thumbnails Relais question series 1-2.jpg   Relais question series 1-3.jpg   Relais question series 1-1.jpg
Old Oct 17, 2016 | 01:55 AM
XJeej's Avatar
I connected the relay and the wipers work, so I suspect it's the wiper relay. Thanks for the pictures and information.
Anthony8858
Oct 8, 2022 03:30 PM
