Removing the electric door mirror
Old Nov 6, 2016 | 01:02 AM
jpb308's Avatar
Default Removing the electric door mirror
Team
Need help removing electric mirror on the passenger door.
Can't see any connectors to disconnect and can't pull the wires through the boot to the outside anyway.
Any ideas please?
Jeremy
Old Nov 6, 2016 | 07:40 AM
Doug's Avatar
Normally the mirror can be removed from the outside of the car but sometimes, as you've experienced, the connectors can't be wriggled out.
Remove the door trim panel and you should find the connectors....which are held together with small wire tires.
Or *maybe* you can get away with simply removing the mirror switch (which itself means undoing two connectors) and finding a way to manipulate the mirror connectors upward and through the hole in the door
jpb308
Nov 6, 2016 06:49 PM
