Reverse Lights inop
Old Jul 18, 2014 | 06:36 AM
djjohnny100's Avatar
Default Reverse Lights inop
1990 XJS V-12. I'm lost. Reverse lights stopped working. Started at the fuse, is ok. Bulbs are ok. No power going to the lights. Disassembled the console. Have two roller switches at the front of shifter mech. Does anyone know which is the reverse switch? No warning lights ever came on. Does anyone have anything to suggest?
Old Jul 18, 2014 | 06:39 AM
jimbov8's Avatar
If you have the console off, put the car in reverse and see which switch is activated and then test it.
Shouldn't be too difficult as you have already done the hard bit.
Should also have posted in the XJS section, hopefully one of the mods will be along to move it for you.
Old Jul 18, 2014 | 07:03 AM
sdduke's Avatar
There is a detent ball type switch near the bottom of the gear selector.
See item 24 of the attached:
Selector Gate and Lever-5.3 Litre-Automatic - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
Chances are the detent ball is gummed up or the switch is bad.
Good luck!
Old Jul 19, 2014 | 11:55 AM
Thanks, cleaned the detent ball switch, they work. I still don't know what the two roller switches are at the front of the shift mech. I will have to look it up. Thanks for your help.
Old Jul 19, 2014 | 12:21 PM
Doug's Avatar
One is gonna be related to cruise control. The other perhaps related to the automatic seatbelts, or perhaps the neutral switch?
What are the wire colors?
Old Jul 20, 2014 | 08:48 AM
sdduke's Avatar
I think the micro switches are for the cruise control and kickdown.
Old Jul 20, 2014 | 09:36 AM
JagCad's Avatar
My vote for the micro switches is one for cruise lock out and the other for neutral start.
My car is an XJ6, r was. I nstalled the XJS column to get the pattern as well as the on tower microswitches and reverse lamp. The reverse lamp switch on the BW's s on the transmission???
Carl
FrickenJag
Jun 16, 2025 02:15 PM
Jpav27
Jul 31, 2022 06:43 AM
neruda
Oct 18, 2015 01:19 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
