S1 Inlet Manifold Vacuum Connections
Old Aug 10, 2015 | 07:40 AM
Woznaldo's Avatar
Default S1 Inlet Manifold Vacuum Connections
Hi All, I've just put in a replacement engine after a bit of a break between taking the old engine out and can't figure out all the Vacuum connections on the underside of the Inlet Manifold.
I'd appreciate if someone could help me out. It's a RHD car if that makes any difference?
Old Aug 11, 2015 | 06:41 AM
o1xjr's Avatar
Mine is parked on the street tonight, but I can have a good look tomorrow morning if that is any help.
Old Aug 11, 2015 | 07:46 AM
Woznaldo's Avatar
That would be fantastic. Thank you.
Old Aug 12, 2015 | 02:03 AM
o1xjr's Avatar
At the front underside of the intake manifold just behind the thermostat housing is a hose(about 1/2") that goes to the brake booster.
On the underside of the manifold between the two carby's is another hose the same size, it goes around behind the engine to the upper left of the firewall to a check valve the continues from there to the vacuum tank tucked in behind the brake booster.
S1 Inlet Manifold Vacuum Connections-dsc_3880.jpgS1 Inlet Manifold Vacuum Connections-dsc_3881.jpg
At the rear underside of the manifold there is a small metal 90 degree pipe pointing to the rear with a hose to the transmission vacuum modulator.
Another larger one connecting both carby's
A small hose off the rear carby goes to the distributor.
Both carby's connect to a pipe that is on top of the manifold and goes to the engine oil breather.
S1 Inlet Manifold Vacuum Connections-dsc_3890.jpgS1 Inlet Manifold Vacuum Connections-dsc_3889.jpg
Hope this helps
Old Aug 12, 2015 | 02:46 AM
Woznaldo's Avatar
Clarkey, your are a legend! Many thanks Sir.
I'm actually fitting an S3 Engine and BW66 Auto Trans. I've just retro fitted the Carbs and Manifold. The obvious difference is between the Auto Trans and the method of Kick Down/Down Shift. The S1 uses the vacuum you speak of above (and the one that had me scratching my head) and a micro switch on the throttle linkage, where as the S3 uses a cable operated system.
I think I should be able to work some kind of bracket and have the correct range of travel.
I'll let you know how I get on.
Old Aug 16, 2015 | 03:55 AM
Woznaldo's Avatar
Ok, I've blanked off the rear most underside vacuum connection and have the started now. There is another vacuum pipe (well, I think it's vacuum) that needs connecting. Its the on the valve (some kind of diaphragm valve) that's connected to the coolant pipe coming of the back of the manifold. It has a smaller vacuum size take off?
Edit: Just had a quick look in my Haynes Manual and found out that the new vacuum pipe issue is for the Heater Water Valve Servo Unit. I'll check it out tomorrow.
Old Aug 16, 2015 | 04:38 AM
o1xjr's Avatar
That is the heater tap to let hot coolant into the heater core/matrix. Yours may look different to mine as one or both of us may an after market item fitted.
S1 Inlet Manifold Vacuum Connections-dsc_3900.jpgS1 Inlet Manifold Vacuum Connections-dsc_3902.jpg
EDIT, I see your edit now. You found it While I was getting pics.
Old Aug 16, 2015 | 07:36 AM
Woznaldo's Avatar
Mines the same as item 5 in the second picture.
Old Aug 17, 2015 | 06:29 AM
o1xjr's Avatar
All 4 of my service manuals and my original dealer parts book show the same as you have, mine looks like one from HQ-HX Holden.
The pic is from the parts book. It was NOS I found in a second hand bookshop still in plastic with 1973 publishing date inside.
If you are chasing original parts numbers for anything send me a PM and I will look them up.
Old Aug 18, 2015 | 07:00 AM
Woznaldo's Avatar
Thanks Clark, very kind of you to offer.
Old Mar 5, 2019 | 11:24 PM
Bismuth08's Avatar
Hello,..someone have the vacuum diagram ??
Old Mar 7, 2019 | 07:43 AM
Robert Laughton's Avatar
Have you installed the S3 engine yet? When I did the same thing; S3 into S1, I found the back of the head at the cams was no longer drilled and tapped. So, there's nothing to mount the throttle cable mechanism to, as the S1 has. I was forced to fab something ugly off a head stud. If you have not installed the engine yet, there's time to drill and tap the RH side. Once the engine's installed, there's no room to do this. Good luck, Rob
Old Mar 8, 2019 | 06:23 AM
Woznaldo's Avatar
Rob, I had the engine running in the car for couple of years before taking it off the road to fix some non engine related issues.
I recently fire her up and the engine still seems to be running well. I don’t remember too many issues with the throttle linkage. everything went together pretty well?
toronadomike
Jan 22, 2026 10:13 PM
clubairth1
30
Sep 3, 2025 04:38 PM
jcwells
Sep 24, 2015 09:20 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
