series 111 V12 fuel pump
Old Jun 5, 2019 | 03:14 PM
prettydaim's Avatar
Default series 111 V12 fuel pump
Hi all, I have been offered a new fuel pump and told it is a oem for 4.2 and 5.3 , 1979 to 1994, my 81 V12 sovereign has a noisy pump with spade terminals (wire ends look original).my question is , is that correct are they the same as I thought to buy 2 and replace the pump also on my 1986 V12 series 111 Vanden Plas.
Old Jun 5, 2019 | 08:47 PM
Doug's Avatar
I'm not sure about the application going all the way to 1994 but, yes, all Series III fuel injected models use the same pump
Old Jun 6, 2019 | 02:27 AM
Agreed,
The XJS had the same external pump 1976 until the intank system arrived.
In the Series3 cars, the 6 cyl, and V12 pump are the same, and also used on Merc, BMW, Aussie Holden and Ford, so nothing special at all.
Old Jun 6, 2019 | 10:16 AM
JagCad's Avatar
The LT1 engine in my car runs fine on the original pump that the Jaguar came with. it is an 83 XJ !!
Caveat: It is laid up now. Quit suddenly. Luckily (?) in my drive. Son will come by later and we will seek to diagnose. Spark or fuel? Best (?) if still in fault mode.
OTH, it may have "fixed" itself and fire right up. ???f
Carl
Old Jun 8, 2019 | 02:28 AM
prettydaim's Avatar
Thank You I am much obliged as they were a bargain 2 pumps brand new $50 AU each so on your advice I purchased them as I was sick of the 81 models singing pump <Kind Regards from Down Under.
Old Jun 8, 2019 | 02:31 AM
prettydaim's Avatar
Thank You ,It's great to have you all to call on, Regards.
Old Jun 8, 2019 | 02:33 AM
prettydaim's Avatar
Thank You, All info is great to receive, Regards .
Vancouver777
Mar 28, 2023 11:05 AM
2009 XF Vail
May 26, 2018 05:18 PM
Vancouver777
Jul 27, 2016 11:50 AM
prettydaim
Sep 7, 2015 05:16 PM
David84XJ6
Jan 7, 2012 07:41 PM
