Series 3 electrical issues
Old Sep 6, 2015 | 12:15 PM
NathanDD6's Avatar
Thanks Doug, I'll have a look at the contacts and try find where the power supply is being interrupted.
Many thanks
Old Sep 7, 2015 | 10:17 AM
Jose's Avatar
Nathan,
is it correct that the blowers WERE running ok and all of a sudden they stopped?
if you look on the bottom and side of each blower case, there is a disconnectable 2-wire plug, sort of hidden between the blower cases, vacuum actuators, and the kick panels.
you might find the connectors and disconnect each connector; then check if there is 12 volt power at each connector (with engine running and mode switch set to AUTO).
if there IS power at each connector, then the issue could be the blower(s) motor(s). They do get clogged with grime and stop running. The only way to really find out what is going on inside the blower case, is to remove it, but...
removal of the entire blower case for cleaning and repair is a nightmare and should be a last resort, in which case you need to follow the removal steps exactly as in the Factory Service Manual. I've done it to mine and I also removed the front seats to prevent any accidents and for ease of working is the confined area.
I'm not saying THAT is the problem, but based on my experience and after trying everything else, it turned out to be clogged motors which after a good cleaning, ran like new again.
also inside the case, there are linkages operated by the vacuum actuator that open or closes a double Flap for fresh air and or recirculation. These linkages are held in place by delicate pins that break apart after the plastic deteriorates and the linkage gets "locked" in place aince they are out-of-alignment.
again, not saying THAT is the problem, but if nothing else resolves the problem after testing the blower power connector, or the Mode Switch, it might come to removal of the entire blower case on each side.
Old Sep 7, 2015 | 10:47 AM
JagCad's Avatar
Agree, electric motors of many specie respond well to cleaning and oiling.
I've done that to revive more than one house fan.
Carl
Old Sep 8, 2015 | 03:21 AM
NathanDD6's Avatar
Many thanks Jose and JagCad, unfortunately I haven't had a chance to check the blowers lately, I'm onto the AAV at the moment, I'll post back what I find, just to add a bit of info the electrical fan in front of the engine doesn't blow either, I don't know if this helps...
Thanks again
Old Sep 8, 2015 | 06:24 AM
Jose's Avatar
if yours is a 12 cylinder, I understand the electric (auxiliary) fan in front of radiator runs everytime the a/c compressor runs, unlike in the XJ-6 which is controlled by a thermal switch and comes on according to a specific temperature.
Old Sep 8, 2015 | 07:12 AM
Doug's Avatar
That's right.
But....since the climate control isn't working, the compressor won't be engaging, either.
The V12s have that as well, thus the e-fan is triggered two different ways. I wanna say 94ºC is the trigger point.
Old Sep 10, 2015 | 04:21 AM
NathanDD6's Avatar
Many thanks JagCad, Jose and Doug
Sorry to have missed your first question there, Jose, indeed the fans were running, and running well, no catching or straining that I could hear, and they didn't slowly get worse or anything, they just stopped.
Doug, the electric fan in the engine bay still works, but only when it is triggered by the temperature sensor in the radiator(?) it does not come on when I turn the fan dial in the car, which I assume it is meant to, can you please point me in the right direction as to where I might find the ignition load relay, I can't find any referance to it in the relay section of the Haynes manual. I'm suspecting a bad connection, I've experienced 2 relays with bad connections already.
Thanks again
Old Sep 10, 2015 | 07:03 AM
  #28
Jose's Avatar
get rid of the Haynes manual, order the Factory CD from the Jaguar Daimler Heritage Trust
Jaguar Heritage
Old Sep 10, 2015 | 08:05 AM
Doug's Avatar
On a LHD car the load relay is in the top left corner of LH component panel. And the component panel is below/behind the LH fuse box.
I've never known if Jaguar reversed the LH and RH fuse boxes and component panels dependent on LHD versus RHD. So, if you don't find the load relay on the LH component panel, look on the right component panel !
Old Sep 10, 2015 | 04:20 PM
  #30
Jose's Avatar
ignition load relay location
Old Sep 11, 2015 | 03:44 AM
  #31
NathanDD6's Avatar
Many thanks Jose and Doug
I'll have a look today and see what I find. The fuse boxes are indeed different in LHD and RHD models, they aren't "mirrored" either from LHD to RHD, the fuses are in a different order. I'll look under both just to be sure of the component panel.
Old Sep 11, 2015 | 05:40 AM
  #32
Jose's Avatar
in LHD cars the components are mounted above the fuse box, and behind the speedometer and tachometer gauges.
To reach them, press each gauge towards the dash and turn them about 1/4" inch clockwise or counterclockwise to release the gauge, then pull the gauge out complete with wiring. Then you can look thought the round opening where all those relays are located.
**do not press on the gauge's glass, only on the frame edges. I think it was David Boger who said if you put masking tape around the metal frame it makes it easier to maneuver the gauge off.
Old Sep 11, 2015 | 06:01 AM
  #33
NathanDD6's Avatar
Thanks for that Jose, quite interesting. I'm RHD but thanks anyway. I think I've got it, little black cylindrical relay right?
Old Sep 11, 2015 | 06:28 AM
  #34
Jose's Avatar
yes, per the picture above
Old Sep 11, 2015 | 12:03 PM
  #35
NathanDD6's Avatar
Many thanks Jose
RHD models have their component panel located behind and slightly below the right-hand fuse box.
Old Sep 11, 2015 | 02:31 PM
  #36
haddock's Avatar
With all electrical probs on the series I always check and thoroughly clean the earth connections. Better still: replace 'm with better connections and thicker wire.
Old Sep 11, 2015 | 03:36 PM
  #37
Jose's Avatar
regarding the fan-blowers:
check the Fans Resistor, (component No. 3) located on the Left side of the a/c unit, above the large Relay, bolted with three small phillips screws to the a/c case.
if this Resistor has burned out, the springs will look scorched, and the fans will not run.
Old Sep 13, 2015 | 09:06 AM
  #38
NathanDD6's Avatar
Good point Haddock, the earths on these cars indeed need regular attention.
Thanks a lot Jose, I'll have a look at them if I don't have any luck with the relay, waiting for better weather down here.
Regards
Old Sep 13, 2015 | 09:28 AM
  #39
Doug's Avatar
I always advise owners to spend a Saturday going around the car to clean-and-tighten every ground point they can find. This exercise, repeated every 10-15 years, preemptively solves 75% of the much ballyhooed "Lucas, Prince of Darkness" problems
Old Sep 14, 2015 | 08:34 AM
  #40
NathanDD6's Avatar
I just checked the relay, it's working perfectly and there is continuity to ground. I read on this forum that there are 4 micro switches that go bad at the fan function/speed selector. Good chance? I suspect this cause the demisting flaps only work when they want to... are they a mission to get to?
