Series I jack - What's it look like?
Subscribe
Mar 13, 2013 | 05:10 PM
Does anyone have any photos of the jack from a Series I XJ6?
Is it functionally any different from a Series II/III car (I presume not)?
Tom
Reply 0
Mar 13, 2013 | 11:53 PM
This is what I found in my trunk this evening. Looks stock but I'm sure others will chime in if its not.
Reply 1
Mar 14, 2013 | 06:29 PM
^ Yep, that's it...
Different from the Series 3 in the way that it cranks..
There should be a tool to crank the Series 1 jack also... (The Series 3 uses the lug wrench)..
The Series 3 also has a solid base that the scissors extend from, where this Series one slides one side on the ground for extension...
David
Everyday XJ
Reply 1
Mar 14, 2013 | 08:34 PM
Thanks guys. Sounds like I should just seek out an S-III jack,unless an earlier one falls into my lap.
Reply 0
Mar 15, 2013 | 07:42 AM
I think it unwise to use such a jack on ANY car that is more than 10 years old!! Get a proper hydraulic lift and use the much stronger suspension to lift the car . And do not forget the axle stands. I had a bad experience of creaking sounds coming from a jacking point whilst lifting a series 2. At the Annual MOT it failed on corroded body parts.
Reply 0
Mar 15, 2013 | 02:43 PM
littlelic: I agree with you, and when working on the car, I always use a hydraulic jack. However, I still need something to carry in the car in case I get a flat. I'll be certain to give a close inspection of the jacking points before I use them.
Tom
Reply 0
Mar 16, 2013 | 12:55 PM
Here are some photos to compare the Series 1 jack (blue) and Series 3 (black) ... Also the tool used to screw the jack, and the different bags that they used to store them.
The Series 3 tool was used both on the lugs, and the jack...
David
Everyday XJ
Series I jack - What's it look like?-img_5171.jpg   Series I jack - What's it look like?-img_5172.jpg   Series I jack - What's it look like?-img_5173.jpg
Reply 1
Subscribe
Currently Active Users (1)
