Series III XJ6 smog pump questions...
Old Apr 10, 2013 | 12:57 PM
Kyle206's Avatar
Default Series III XJ6 smog pump questions...
Hey everyone pulled my seized smog pump off today with the intentions of installing the new one I special ordered through Pep Boys. I checked the new one to make sure it was in fact the correct one (all of the holes lined up ect.) so I pulled the old one off and removed the pulley and the studs for mounting the diverter valve and both the studs and bolts are much bigger than the original ones I pulled out (shown in picture below)
So now on to my question, Did I receive the wrong smog pump or can I "simply" go to the hardware store and get the correct size bolts/studs?
Secondly, I live in California currently but I am moving to Arizona this month. With that being said does anyone know if I deleted the smog pump if it would throw off regular Arizona emission as they do not "smog test"?
Thank you for looking!
Old Apr 10, 2013 | 02:45 PM
Kyle206's Avatar
Old-
New-
Old-
New-
Attached Thumbnails Series III XJ6 smog pump questions...-img_6634.jpg   Series III XJ6 smog pump questions...-img_6633.jpg   Series III XJ6 smog pump questions...-img_6632.jpg   Series III XJ6 smog pump questions...-img_6637.jpg   Series III XJ6 smog pump questions...-img_6638.jpg
Old Apr 11, 2013 | 10:12 AM
JagCad's Avatar
Two ideas:
1. Just get the hadware store sourced fasteners that fit and bolt it on.
2. Check on AZ requirements. If none needed, dump it!
I know of one CA guy that just removed all of it and neatly plugged the holes. A SMOG tech never noticed it wasn't there.
I've done that twice in the past relying on model issues on two cars. A 65 registered Mustang with 66 stuff. I returned it to 65 status. Same with a 68 Toyota registered as with 69 stuff. I returned it to 68 status. Made it look as built and all went just fine.
Old Apr 11, 2013 | 02:45 PM
Kyle206's Avatar
Originally Posted by JagCad
Two ideas:
That actually sounds like a good idea. The engine bay looks way better without it and its one less pulley without it in there. I may try that and if they "catch me" I'll take a trip to the hardware store and spend $5
pnwrs2000
Jan 15, 2018 07:20 PM
Charlene n John
Sep 14, 2015 12:01 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
jagent
Sep 7, 2015 05:00 PM
Jag-o-nomic
Sep 4, 2015 03:07 AM
