SIII Rat / resto mod update
Old Jul 5, 2018 | 08:37 AM
Rustyxjc's Avatar
Going to be interesting to see how you wire this up !
Originally Posted by andys-GR
Old Jul 5, 2018 | 08:58 AM
andys-GR's Avatar
I'll post pics as I do it. As I'm removing the existing turn signals and side lights its should be pretty straightforward. I will need to run additional wires to the inner head lights for the 'running' lights.
Old Jul 21, 2018 | 07:31 PM
andys-GR's Avatar
Default New Head Lights, Halo and integrated turn signal
Got around to installing the new head lights, pretty happy with the results. Used Plastic buckets from the UK for MG / Triumph.
Old Jul 22, 2018 | 03:09 PM
Rustyxjc's Avatar
Wow that turn signal is really bright I like all of It!
where did you get Lights?
Rusty
Old Jul 22, 2018 | 07:03 PM
andys-GR's Avatar
e-bay here's the links
https://www.ebay.com/itm/7-Crystal-W...72.m2749.l2649
https://www.ebay.com/itm/5-3-4-White...72.m2749.l2649
Rusty
Old Aug 25, 2018 | 06:04 PM
andys-GR's Avatar
Default Dash / Center Counsel Update
Slow progress finally got another afternoon to work on it. The switch gear is all connected and working. The touch screen head unit is next to install. The dry fit still needs tweaking but is getting close, had to share pics
Old Aug 25, 2018 | 06:25 PM
Rustyxjc's Avatar
Starting to come together! Please review the head unit . i like the size alot!
Rusty
Old Aug 25, 2018 | 07:25 PM
  #28
andys-GR's Avatar
I'll do a review when I have it fully wired and working. Below is a link to the unit. I've split it into two separate units. It easily disassembled and the pig tail for the screen is long enough to bridge the gap. amking space for the wiring harness for the switches and the head unit is going to be tight.
Here's the unit:
https://www.ebay.com/itm/HIZPO-10-1-...AAAOSwdnZaK0aG
Rusty
Old Aug 26, 2018 | 04:44 PM
Yellow series3's Avatar
Wow, that is a very attractive price. All the sudden I am looking off into space and saying hmmm. All that and cup holders. Are the toggle switches going to have lables? I love the look but I have trouble remembering which of my toggles go to what and I installed them.
Old Aug 26, 2018 | 07:23 PM
  #30
andys-GR's Avatar
The far left switch (fuel change over) has illuminated arrows showing left / right the other switches down't have labels. I was going to water jet cut letters to label them but decided against it.
Old Oct 20, 2019 | 09:58 AM
  #31
andys-GR's Avatar
Default Slow progress....
So time has been limited, this last month I've got to spend time with her. But it went togther and worked. I've had to change the head unit type as there just wasnt room for the single DIN 'box' behind the switch gear with all the switch wiring. Fortunately the market has moved on and the same style unit is now available with all the electronic fitted 'flat' to the back of the display (i'll post pics soon). Wanted to share these !!
Old Oct 20, 2019 | 09:23 PM
  #32
LT1 jaguar's Avatar
Active Streak: 60 Days
It's obvious that you have put a lot of work and thought into your car. The bumperettes are like the race version of the Cobra kit cars and, of course, the original race cars.
Thanks for sharing your work.
Dave
enderle
E type ( XK-E )
64
Sep 16, 2025 10:19 PM
jagent
Sep 12, 2015 09:10 AM
DevilDog
Oct 5, 2014 09:18 AM
