Starts, runs rough, dies?
Old Mar 15, 2026 | 07:55 AM
Logan756's Avatar
Default Starts, runs rough, dies?
I was driving my 86 XJ6 with the 4.2L, and as I picked up speed to about 50 the engine started cutting out terribly. Then as I got to about 60 it would sound like its stumbling on maybe 2 cylinders before it just wouldnt really start again. I can start the car with the throttle wide open and it will run on maybe 2 or 3 cylinders barely before dying out. I had it sit for a while and was able to get it to run okay but after a few attempts it started doing the same thing. It will not idle though. I verified all my spark plugs are good and firing, and I dont believe the timing would randomly kick out. Im trying to figure out what it could be? I attatched a video below of what it js doing
Old Mar 15, 2026 | 01:44 PM
sov211's Avatar
Well, first, the scenario you describe is that of a fuel tank running dry. Did you try switching tanks?
Old Mar 15, 2026 | 02:33 PM
David84XJ6's Avatar
Once it dies, try putting transmission in Drive and turning ignition to start and listen for fuel pump running in truck. Try 3-4 times holding 3-4 seconds each time. Transmission back to Park, If car starts and run a while, I would suspect Fuel filter.
Rgds
David
Old Mar 15, 2026 | 02:56 PM
Logan756's Avatar
Fuel tanks are full, and I have run the fuel system off of a gas jug as well and it does the same thing. If I pop the return line off the fuel rail tons kf fuel pours out. Pulled out the injectors and verified they are firing
Old Mar 15, 2026 | 02:57 PM
Logan756's Avatar
Rgds
David
Car will not stay running long enough to do this unfortunately, but I will put a new fuel filter in anyway as I am sure it wont hurt. The car will not idle at all, only starts with throttle open
Travis_22
Jun 3, 2025 12:21 PM
tobywood13
Feb 27, 2024 03:05 PM
Terry
Aug 19, 2014 05:39 PM
Daim
Jun 6, 2014 02:39 PM
jkjag
Feb 7, 2012 12:01 AM
