Steering rack bellows
Old May 3, 2011 | 05:33 AM
njk1963's Avatar
Default Steering rack bellows
Can anybody tell me if the steering rack bellows on my 1977 xjc should have a clip on each end?
in the haynes repair mannuel is shows only 1 on the inner end, but my car has them on both ends
thanks
Old May 3, 2011 | 05:52 AM
The larger end is "normal" to have a clamp of sorts, the smaller end is usually unclamped.
The smaller end is usually clamped to stop the oil running out, coz the rack is leaking and the car is for sale, or needs rego testing where oil leaks means a FAIL, so a clamp here stops the leak for a small time. Seen it many, many times.
If yours is NOT leaking, leave it unclamped. This also prevents bellows "wind up" caused when wheel align people turn the rods for setting purposes and dont worry about destroying the bellows, brain dead in my opinion.
Old May 3, 2011 | 09:58 AM
njk1963's Avatar
thank you for the tip.....suspect they may have been leaking greese...fingers crossed its not a major problem
Old May 4, 2011 | 02:41 AM
RHD ????.
If grease from the RH bellows, it has been OVER GREASED, through the nipple on the underside of the rack, quite common, and generally does NOT cause issues, although some have reported issues with the practice. A couple of pumps per year is all that is required at this grease point.
If the grease is from the LH side, you may have issues, that is IF it is grease, and not just "gluggy" fluid/dust stuff.
Replace them, and change the fluid with "Power Steer Fluid", and enjoy.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Woznaldo
Sep 26, 2015 11:02 AM
