Steering rack bent tie rod
Old Nov 15, 2013 | 04:57 PM
Chris Willis's Avatar
Default Steering rack bent tie rod
Ran into a curb on oil slick road at about 20 mph . Right front. Replaced wheel. Took to get alignment. Shop said inner tie rod bent and rack leaking . $ 680. To fix and align. Leak doesn't seem bad ,yet. How can I tell if it's bent . Can I replace or where do I get rebuilt rack . I didn't ask if they were doing the entire rack or just fixing one side . Can they fix one side? Seems like I should do whole thing if any . 1986 xj6. 45,000 mile car Thanks guys
Old Nov 15, 2013 | 05:11 PM
Doug's Avatar
I've had good luck with rebuilt racks from Coventry West 800-331-2193
I doubt that the repair shop is repairing your existing rack. That's not the typical procedure as rack rebuilding/repair is a bit specialized.
Old Nov 15, 2013 | 06:09 PM
I'm seeing the inner tie rod available . Have u changed just that?
Old Nov 15, 2013 | 06:23 PM
Doug's Avatar
The inner tie rod is inside the rack. I've never had a rack apart, personally.
Old Nov 15, 2013 | 08:34 PM
icsamerica's Avatar
Default rack
I've got a few racks from Rockauto. Good prices, quick delivery, no problems and easy core returns.
Old Nov 21, 2013 | 12:18 PM
Default alignment
had alignment done on xj6 the shop said camber was close enough ,adjusted toe-in and said caster was off. their measurement was +1.25 on driver -.05 pass. we dont have Jag shims he says .. I drive home drifts right .. look in book and it says +2.5 + / - 1/4 the shops book said 3.5....moving shims from top of ball joint one of the easier things ive done on my jag . obviously they just didnt want to mess with it . Heres question, I miked a shim and it was .065 I moved one from left side to right . more leaning back . Was explained like the front fork of a motorcycle but not as severe. and it improved. how many degrees does one .065 shim move it???? also the Haynes manual ( yea I know everybody laughs at it) says there should b 4 or more shims ..I have 3 I feel like both sides need another shim to get closer to 2.5
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Woznaldo
Sep 26, 2015 11:02 AM
