SU carbs for an XJ6
Old Nov 25, 2024 | 09:10 AM
Mguar's Avatar
Default SU carbs for an XJ6
I’ve been told that XJ6 in ENGLAND had the two HD8 (2”) SU. Carbs. If that is correct what is the market price of those and who is a source I can find some decent used ones from?
I’m putting a supercharger I have on a V12 and would like the carbs to be SU’s.
Old Nov 25, 2024 | 09:59 AM
Jagboi64's Avatar
Depends on the years. Early cars would have had HD8, by the 70's they has HS8 and some later cars had HIF44. I have used all 3 on various cars, I prefer the HIF44, just make sure to change the choke valve O ring to a viton or other material that is compatible with modern fuel.
You can get any of these on Ebay UK. They don't have to be a Jaguar application, late Mini's used a single HIF44 for example.
Old Nov 25, 2024 | 11:01 AM
Mguar's Avatar
Thanks you. I already have 4 HD8’s and I’m looking for 2 more. Are they rare and expensive in the UK ? Or reasonable?
Old Nov 25, 2024 | 08:13 PM
Jagboi64's Avatar
I've never shopped for HD8's, so I don't know what they sell for now. E Type stuff is very expensive, not sure about the other applications.
Old Nov 26, 2024 | 01:28 AM
Andy T.'s Avatar
Burlen Services in Salisbury are the manufacturers of SU. They have HD8s available new:
https://sucarb.co.uk/pair-of-hd8-yje...l-1968-71.html
Old Nov 28, 2024 | 04:39 AM
garethashenden's Avatar
You want 6 carburetors on a supercharged V12? That sounds like a tuneability nightmare, but you do you!
Old Nov 28, 2024 | 10:22 AM
Jagboi64's Avatar
Sounds well over carburetted too. On the injected engines, the throttle ares is about 9.8 square inches, and that can support in excess of 500hp. 6 HD8 carbs is double that area, so seems overkill to me.
Old Nov 28, 2024 | 05:18 PM
Mguar's Avatar
Two things.
1. Supercharging requires at least 40% more air than normally aspirated. In addition I’ll be using E85. (85% ethanol) that requires as much as another 50%. (It both cools the heated intake charge and adds significantly to the intake requirement.).
2. Alcohol is extremely tolerant fuel mixture wise. ideal gas is 14.7 parts of air to 1 part of fuel. Deviation over 1% is a serious problem.
Alcohol ideal is 9.8 parts of air to one part of fuel but will tolerate as lean as 11.5-1 or as rich as 8,6-1 without any serious issues.
Since the Venturi is variable SU’s tolerate being oversized and adjusts itself according to actual need.
3 HD8’s on a 4.2 XKE is seriously oversized but works very well.
With a race car I will likely be able to get real close to the full potential of a 5.3. V12.
If they don’t work I’ve got 6 Strombergs and worst case 6 1&1/2 inch SU’s.
Now for on the street using gasoline the Six 1&1/2 inch SU’s would probably work best.
wayne1991
Nov 28, 2024 05:21 PM
waheed1969
Apr 25, 2024 04:43 AM
mikega
May 14, 2023 04:51 AM
oscarvelay
May 27, 2021 07:03 AM
Wascator
Sep 11, 2019 11:37 AM
