Tachometer trigger wire clarification needed
Old Mar 1, 2025 | 08:42 PM
TooManyJaguars's Avatar
Default Tachometer trigger wire clarification needed
1976 XJ6, converting over to contemporary ignition, which only needs 12v power and ground.....
As l recall, the tach trigger wire is white with a blue stripe?
And maybe needs to be connected to the negative side of the coil, through the elegantly finned resistor?
Thanks in advance for any suggestions 😊
Old Mar 2, 2025 | 10:14 AM
Doug's Avatar
The wire might be white/slate/blue.
I not really familiar with Series II specifics. However, I'm fairly certain that the tach will work with a simple trigger wire to the coil "-" post. The finned resister sounds like something from the old OPUS ignition system; I don't think it actually has any bearing on tachometer operation.
Let's hear what others have to say
Old Mar 2, 2025 | 08:03 PM
Thank you, Doug....Just want to make sure l don't create a new problem 🙄
stan73
Apr 9, 2024 11:44 PM
727gs
E type ( XK-E )
Nov 29, 2021 08:36 PM
geneo
Apr 11, 2020 03:24 AM
Colfod
E type ( XK-E )
May 11, 2018 06:13 AM
patpin
Aug 26, 2016 10:16 AM
