Tail, Interior/dash lights 85 XJ6 are off
Old May 2, 2021 | 06:14 AM
mikega's Avatar
Default Tail, Interior/dash lights 85 XJ6 are off
The dashboard and all the interior lights of my 85 XJ6 are off except park break which is permanently on.
The tail lights are also off.
how do I fix this?
Old May 2, 2021 | 09:11 AM
Doug's Avatar
With any lighting faults begin by checking the bulbs and fuses.. And 'checking' includes cleaning away any corrosion on the contacts.
Do you have a 12v test light? it would be helpful.
You've mentioned several different lighting circuits so you may have to diagnose them individually. Some of them might share earthing/grounding points, though...so cleaning the grounds might be the fix.
Do you have the S57 wiring guide? It would be very useful here
Old May 2, 2021 | 04:30 PM
mikega's Avatar
Thanks DD,
i did some corrosion cleaning around the fuses at the driver side and the lights are working now.
But, when I switched on the high beam, it's only the driver side that works whiles the passenger side high and low beam goes off bit when switch to low beam, the two sides low beam works fine.
Where and what do I check to fix the passenger side problem on the low and high beam when high beam is switched?
Old May 2, 2021 | 10:11 PM
Andy T.'s Avatar
There is a separate fuse box for the headlamps and electric cooling fan on the left side inner wing in the engine bay. Start by checking for bad fuses and poor connections there.
Old May 3, 2021 | 02:37 AM
mikega's Avatar
Andy, i did the check that but seems bad connection as suggested but still problem exist, I will test the fuses to check.
Interesting side of your submission is, how do connect electric modern car fan if I want to change the existing fan on the engine?
Old May 3, 2021 | 02:49 AM
Andy T.'s Avatar
Your car should already have an auxiliary electric cooling fan in front of the air con condenser.
Best to continue this aspect of the discussion in your other thread about over-heating
Old May 4, 2021 | 04:18 AM
Malcolm Ridgway's Avatar
Default Bullet connectors etc
how do I fix this?
I cleaned all the bullet connectors between fuse box and lights and the earths - that worked
whitney12
Nov 24, 2014 07:03 PM
edselsouth1
XJ40 ( XJ81 )
Sep 27, 2012 01:36 PM
jagclaude
Jul 26, 2012 02:58 PM
swoop22
Nov 1, 2011 06:48 PM
Darel
XJ40 ( XJ81 )
Sep 24, 2008 08:30 PM
