Transmission Problem, Help!
Old Jan 14, 2008 | 06:02 PM
lovethemcars's Avatar
Default Transmission Problem, Help!
I recently bought a 1984 XJ6 with an automatic transmission, but when I took it out for a test drive my transmission crapped out. I was doing a 3-point turn and tried to put the car in reverse, but it would go, I was moving the shifter but I couldnt here the gears catch. It then would not move out of park. When I finally got it to go forward after so jerking around I noticed that one rear tire wasnt moving when the gas was on! The past owner told me it had a problem with the linkage, I am reasonably mechanically competent, but I fear this is beyond my skill to repair. Any advice on what the problem might be or how much it will cost to fix would be awesome!
Old Jan 14, 2008 | 07:01 PM
FactoryJaguarTech's Avatar
Default RE: Transmission Problem, Help!
I am sorry to say that there are too many variables in that one. On the plus side, that vehicle has I believe the GM trans in it. So if you have problem you should be able to get it rebuilt pretty inexpensively.
Old Jan 14, 2008 | 09:16 PM
right now it has to be towed, should i take it to my local import mechanic, or go to a nationwide chain like cottman's or aamco?
Old Jan 14, 2008 | 09:17 PM
also, what would help narrow down the list of possible causes?
Old Jan 15, 2008 | 07:08 PM
I am sorry.....but I am not good with that era of Jag. Basic stuff on those I can do, other than that maybe one of the others could help with.
Old Jan 16, 2008 | 09:05 AM
ken@britishparts.com's Avatar
The XJS had the GM transmission. That one has a BW66.
RoyLittle0
May 25, 2023 02:38 AM
jdzubas
Oct 4, 2015 09:14 AM
XJsc-guy
Sep 25, 2015 11:09 AM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
