Twin SU Part Question
Old Sep 14, 2019 | 06:13 PM
Mearsy101's Avatar
Default Twin SU Part Question
I need a couple of question answer about my XJ6 Series 2 1978
The carbs look like they are missing something on the top of them but I can't find the name of the part, I have seen from photos and there is a bar that runs in between the two I'm not sure how important it is to have.
Second is does anyone know where I can find the rubber grommet located on the left it has perished.
Old Sep 14, 2019 | 09:24 PM
Mikey,
Its been YEARS, but that was once a vac hose and memory is, part of the AED choking device/emissions nonsense.
Mine were all plugged, and similar to that in the day.
Fuelmiser has a kit HYP-59, from Sprints years ago, and is a selection of blanking plugs/caps. Sadly they dont last long in there, so a fuel hose and a cut off bolt does the job.
Not sure on the grommet you are asking about.????
Old Sep 16, 2019 | 07:00 AM
yachtmanbuttson's Avatar
I think the grommet you are referring to is really a bushing for the shaft turning the butterflys in the carbs. I had to make mine out of brass.
Old Sep 16, 2019 | 09:10 AM
Bill,
Well done, I did not see the 2nd red circle, joys of one eye.
Yes, it was a bush, probably still available, but a brass etc is the best.
Old Sep 17, 2019 | 09:53 AM
4catstudio's Avatar
If you have no luck elsewhere, this is the go-to guy in the US for SU carbs, so he may have the linkage bits.
JOE CURTO, INC.
Old Sep 17, 2019 | 01:09 PM
He's also the GO TO guy for Strombergs. And gives OUTSTANDING service! Highly recommended.
mgreene
Mar 6, 2019 02:58 AM
Krud
May 30, 2016 02:20 AM
Josh Miller
Aug 29, 2015 08:23 AM
Anfield Dreaming
Sep 10, 2014 07:07 PM
Mitchh29
Mar 2, 2012 03:53 AM
