under bonnet sound proofing
Old Nov 1, 2013 | 03:56 AM
adrianbond's Avatar
Question under bonnet sound proofing
Hello Everybody
does any one know if the under bonnet sound insulation is available for a 1985 series 3 , or at least a part number for it.
Adrian
Old Nov 1, 2013 | 04:43 AM
Gippsland's Avatar
WhiteXKR ? I think?
Has them for the X308's. Thinking that shouldn't be too different.I brought one and it doesn't appear to be "preformed". I have not used it,or taken it out of the box.
If you search here for "hoodliners" (appears to what the Americans call them) . The 3M 80 adhesive was a little harder to find but I if you go along these lines I know where to get it now. What I liked is he does them with a Leaper Logo if you want it.
Old Nov 1, 2013 | 04:56 AM
Adrian,
I can only find part Numbers for the two piece Series III XJ12 OE Bonnet Insulation Pad but it should be the same for all variants of the Series III:
BEC22723 - Front
BEC22724 - Rear
These are unlikely to be available from Jaguar but for an aftermarket (and better) solution, forum member Gonzo is the man for bonnet insulation pads a.k.a. hood liners:
About My Hoodliners
Old Nov 1, 2013 | 04:57 AM
Gippsland's Avatar
Adrian,It is "the jag wrangler" He has a web site if you would like to google him.Have a feeling he was a bit crook for awhile.
I will have to learn how to post "links" ! But I;m sure he could answer your question. Was not that expensive either. $120/30ish from memory.
Poet
Feb 7, 2025 02:18 PM
GGabriel
Nov 22, 2018 03:53 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
vwbusbits
Oct 13, 2015 03:43 AM
Rocky15
Sep 28, 2015 04:59 PM
