V12 long block weight
Old Nov 7, 2011 | 04:17 PM
Per's Avatar
Per
Default V12 long block weight
I need to pull a V12 and then move it into a workshop without trolleys, cranes or similar. Thus I plan to strip it leaving the block with internals, heads, and preperably camshaft carriers in place. I will remove ancilliaries, external piping, manifolds, dizzy, crankshaft damper etc. What is the weight of the engine in this state, alternatively without cams and cam carriers?
Old Nov 7, 2011 | 04:49 PM
ronbros's Avatar
average weight complete is around 750lbs. so with all outside components removed a rough guess would be 650lbs.
YES they are quite heavy.
Old Nov 7, 2011 | 04:54 PM
ronbros's Avatar
Default some pix of engine on stand,V12
couple pix.
Wolfy
May 28, 2024 08:06 AM
Doug
Feb 27, 2019 01:31 AM
prettydaim
Sep 10, 2015 04:27 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
d a
Sep 3, 2015 02:34 AM
