VIN # not correct???
Old Jul 27, 2011 | 05:12 PM
larryc182's Avatar
Default VIN # not correct???
i try to use the vin # to verify correctness of parts. The answer comes back as invalid or check digit incorrect.
the number is stamped on a piece of metal in the engine compartment, so i do not know what could be wrong.
VIN# SAJJAYLS4CC340971
any help would be appreciated.
thanks
larry
Old Jul 27, 2011 | 05:56 PM
Doug's Avatar
The "piece of metal" on the cowl panel/firewall about where the two fender braces come together? If so, that's the original "born with" VIN and won't compute on any database that's set up to for North American VIN decoding.
Try the vin that's on the winshield pillar. That'll be the one Jaguar assigned to comply with USA regs.
Also, the databases you are trying simply may not be set up to decode older Jag VINs no matter which one you use.
Old Jul 28, 2011 | 03:10 PM
86JAGVP's Avatar
You might have one to many J's in the VIN# I would expect it should be SAJAY....
Old Jul 28, 2011 | 04:09 PM
larryc182's Avatar
Smile Vin
Thank you very much!
larry
MrWhite
19
Jun 14, 2022 07:49 PM
jagent
Jun 5, 2022 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
LilaJagHubby
Oct 1, 2015 01:47 AM
42Ajd
Sep 26, 2015 07:04 PM
