volt gauge reading low
Old Sep 20, 2014 | 06:54 PM
dansxj6's Avatar
Default volt gauge reading low
My 1987 series 3 dash volt gauge reads just a hair under 13v when running. I put my multimeter on the battery itself whist running and it reads 14.3v I assume its dirty connections but where do I start?
Daniel
Old Sep 20, 2014 | 08:08 PM
Doug's Avatar
What does your handheld voltmeter read at the green wire at the back of the dashboard voltmeter? If the reading here is 14.3 but the gauge on shows 13, there's an adjusting screw on the back of the gauge to correct the reading.
If not....
What are you reading on both sides of the #4 fuse in the main (left) fuse panel? This fuse feeds the gauges. Is the fuse clean?
Start at the battery cables themselves, then the two "+" junction/distribution posts on the firewall, and check/clean/tighten the main ground under the car where the trans and engine come together.
If nothing improves we can dig deeper.
Old Sep 21, 2014 | 10:21 AM
JagCad's Avatar
Mine usually reads just a tad under 13. As, I've checked real voltage with my patch cord to my VOM and found it just fine, I don't concern myself with a minor variation on the fascia instrument.
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
giandanielxk8
Sep 6, 2015 07:21 PM
jaguarbill
Sep 5, 2015 11:43 AM
AL NZ
Sep 4, 2015 08:39 PM
