View Poll Results: Help with weak low beams
Headlight control module?
0%
Fuses?
0%
Voters: 0. You may not vote on this poll
Weak lowbeams
Old Mar 8, 2021 | 01:09 PM
Johnny J's Avatar
Default Weak lowbeams
I am helping a friend with his 1995 xjs 6 cylinder convertible, usa model. His problem is that his low beams are very dim while the high beams are normal. Apparently, the problem started when he was driving at night.
I don't have access to the vehicle yet so I'm doing troubleshooting by looking thru his manuals. I was originally told that the low beams didn't work at all but they do work, they are just very dim.
I originally thought the headlight control module was bad. Now, I'm not so sure. It's not a grounding problem as the high beams are bright as they should be and they share a common ground.
It's evident that something is pulling the voltage down to the lower beams. I was told to check fuses but then there is power to them.
Any help would be appreciated. Thanks.
Old Mar 8, 2021 | 02:06 PM
Doug's Avatar
Best to repost your question in the "XJS" section
shula
Apr 2, 2010 06:41 AM
tvn300
Feb 13, 2010 07:48 AM
jvegas
Sep 10, 2008 07:35 PM
estunum
Exterior
Feb 25, 2008 04:37 PM
