What is this?
Cruise bellows, not sure.it would.create a vac leak unless cruise was trying to engage, if vacuum was on bellows all the time it would be trying to open throttle all the time,
Anyhoo, its a good place to.start if you wamt to get your cruise working again
I opened it up, it’s all in good order, just the brass plate was at an angle due to the worn out rubber bellows, the spring behind it was pushing it out. Ordered a new bellows cover. 😊👍🏻
