What is this?
Old Oct 9, 2017 | 01:25 PM
Quantumleap67's Avatar
Default What is this?
This brass looking plate was off with the spring sticking out...what does it do? I’m a decent shade tree mechanic but haven’t seen this yet. The boot is loose too
Old Oct 9, 2017 | 02:31 PM
pjprofili's Avatar
Cruise control bellows. Assuming it's plumbed in then that gap will be causing a massive vacuum leak!
Old Oct 9, 2017 | 05:04 PM
Darrenmb's Avatar
Veteran: Navy
Cruise bellows, not sure.it would.create a vac leak unless cruise was trying to engage, if vacuum was on bellows all the time it would be trying to open throttle all the time,
Anyhoo, its a good place to.start if you wamt to get your cruise working again
Old Oct 9, 2017 | 05:33 PM
Jose's Avatar
looks like it has been crushed, you might need the entire assembly, unless the photo is skewed.
Old Oct 10, 2017 | 12:54 PM
I opened it up, it’s all in good order, just the brass plate was at an angle due to the worn out rubber bellows, the spring behind it was pushing it out. Ordered a new bellows cover. 😊👍🏻
