What Front Pads to use?
Old May 20, 2022 | 02:00 PM
4catstudio's Avatar
Default What Front Pads to use?
I’m upgrading a 1977 XJC to 4 pot calipers.
What’s your experience or recommendations for a good street performance pad?
Thanks.
Old May 20, 2022 | 04:21 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
I am using these on my S3 and they feel very good.
Bosch BP135 Semi-Metallic Front Pad Set (from Amazon)
Dave
Old May 20, 2022 | 04:38 PM
Yellow series3's Avatar
Not on my XJ6 but my 2007 Vanden Plas had the original pads that made a ton of brake dust that was always coating the wheels. I installed Ceramic pads. I had read where they were hard until warmed up, required more pedal pressure, etc. I’ve been driving with them for a year now and I feel absolutely no change in performance from the stock. And zero brake dust. I highly recommend ceramic especially if brake dust is a concern.
Jeff
Old May 21, 2022 | 08:31 AM
Darrenmb's Avatar
Veteran: Navy
I second the ceramics, I have wire wheels and went with them for the lack of brake dust, but I also installed drilled and slotted rotors, mine does require a bit more pedal effort, but they will stop this beast in a hurry!!! Mind you, I did all 4 that way!!
GordoCatCar
Feb 1, 2020 01:45 AM
Johnny_B
Jul 4, 2018 08:48 PM
giandanielxk8
Jan 13, 2018 08:20 PM
Boston Joel
Sep 6, 2015 08:08 AM
