what"s behind glove box
Old Apr 14, 2017 | 07:50 PM
Frank Trebel's Avatar
Default what"s behind glove box
I'm redoing my XJ6C dash and I have the dash out and I saw two things behind the dash that I need help with.
First....there is a white plastic counter system attached to the speedometer cable. It's located right behind an inspection panel in the glove box/ Anyone know what it's function is????
Two....there/s a large round white plastic plug located at the right hand end of the dash with about 6 or seven connections on it. Anyone know what its function is????
Thanks for the help:
Old Apr 14, 2017 | 07:59 PM
Doug's Avatar
Sounds like an "Intervalometer". On Series IIIs such a device was used to turn on the "Oxygen Sensor" light every 30k miles. Not sure what the function is on a Series II
I'm stumped on that one.
Old Apr 14, 2017 | 09:31 PM
Looks like this?
Among other things, this is the Seat Belt Warning component. It may also warn of the key left in the ignition with the door open. There may be other warnings but I've not discovered those yet.
Old Apr 15, 2017 | 02:36 PM
Thanks LnrB.....that answers one question but I'm still wondering about the other counter. It's also a white plastic box inline with the speedometer cable and it says on it....Smith Industries, sig 1002/250, % laps used. and in the counter window it is showing the number 359. can anyone explain this counter????
Old Apr 15, 2017 | 04:02 PM
You're very welcome. I had to ask what that thing was too.
I don't have any such counter, but I don't have a Jaguar engine in my car either, so I can't help you with that.
Maybe Doug has it right, and it's something to do with the oxygen sensor. I don't have one of those either.
Old Apr 15, 2017 | 07:45 PM
Doug's Avatar
FWIW.....
The Series II catalog does show the interval counter for Canada, Japan, and USA cars "with 25,000 mile catalyst only"
Old Apr 15, 2017 | 11:00 PM
OK Doug.....but what does this interval counter actually count???
Old Apr 16, 2017 | 01:30 AM
Doug's Avatar
Miles driven.
Do you have an oxygen sensor warning light? If so, the interval counter is what turns it on (apparently every 25k miles)
Old Apr 16, 2017 | 08:36 AM
JagCad's Avatar
Yup, like Elinor, my O2 mnileage counter light in the dash departed. The counter itself remains but unused.
I removed that little lamp and holder from the dash. Fellow lumper made a transparency to insert. It now glows "CHECK ENGINE" on turning the key to start. so far, so good, it goes out shortly. My SMOG referee was impressed.
The Information Center" on my Jeep has a counter for a 3K service interval. It counts back from that number!!!!
Along with a figure of a door ajar, a lamp out or the windshield washer bottle "low"!!!
Carl
Carl
Old Apr 18, 2017 | 10:44 AM
I do have a 'Catalic/EGR" light that is separate from the center strip of lights that are between the Tach and Speedometer. I have never seen it on at all. I'll get a new bulb in it before the new dash goes in.
Old Apr 19, 2017 | 08:42 AM
JagCad's Avatar
Frank:
That is the service interval counter light. It should light up after the counter counts of the designated miles. 25?
Do you have an owner's manual? If so, it should describe the function. If not, advise, I'll check mine and quote. Might even be able to scan and attach the page. Not sure there on this machine. it is quirky about attachments.
Should you not have the manual, I recommend you get one. Quite helpful...
David Boger at Everydayxj can probably provide a decent one.
Carl
rl
Old Apr 23, 2017 | 09:23 AM
i have an owners manual and a repair manual and neither mention this counter . They don't even show the EGR/Catalyst light that I have on my dash. Thanks for all the replys and help.
