Wheel bolt pattern question
Old Nov 27, 2015 | 09:53 PM
OMGPirate's Avatar
Default Wheel bolt pattern question
So, I have looked around a little bit, and I haven't found a straight answer yet. What is the wheel bolt pattern on the XJ6 Series 3?
Old Nov 27, 2015 | 10:34 PM
Doug's Avatar
5 on 4.75"
Very common
What isn't common is the diameter of the center hole. 2.875" or something like that. Bigger than most
Old Nov 27, 2015 | 11:25 PM
OMGPirate's Avatar
Thank you kindly Doug!
So in metric that is 5X120.7 correct?
what would 2.875" be in metric readings if anyone knows or where could I find the conversion for it as well?
Old Nov 28, 2015 | 12:17 AM
Doug's Avatar
usually stated as 120.65 mm
2.875" x 25.4 = 73.03 mm
I'm not 100% certain on the 2.875" though. Measure one of your own wheels
NathanDD6
Dec 11, 2015 09:48 AM
joesoap
Dec 1, 2015 03:47 AM
Harry Dredge
New Zealand
Nov 27, 2015 01:02 PM
BC XJS
Nov 27, 2015 10:29 AM
XJLFTW
Nov 27, 2015 05:03 AM
