Where can I get a stub axle flange bolts?
Old Oct 2, 2012 | 10:11 PM
FastKat's Avatar
Default Where can I get a stub axle flange bolts?
I pulled my stub axle assemblies out of the differential to do the seals and one of my friends noticed that a couple of my stub axle bolts were damaged. These bolts go through the 4-bolt flange on the stub axles, through the brake discs, and through the inner axle flanges by the inner U-joint.
Anybody know where I can get a couple of these? I called the local Jaguar dealer, and they only sell the whole stub axle assembly. I was hoping to buy one used. Any ideas - maybe someone has a worn out differential sitting around for parts?
Old Oct 3, 2012 | 06:05 AM
Try XK Unlimited in San Loius Obispo. They have helped me with weird and wonderful items over the years.
Old Oct 3, 2012 | 06:21 AM
Roger Mabry's Avatar
Default I bought them from these folks
When my IRS was out, one of mine was broken. This place had them in stock and they came with LocTite (S3 type) installed instead of the holes for the safety wire.
(909)946-1809
Work
(800)231-3588
Work 2
(909)946-3398
Work fax
Address
Exotic Car Parts
923 N Central Ave # D
Upland, CA 91786
United States of America
Old Oct 4, 2012 | 09:44 AM
FastKat's Avatar
Thanks for the responses guys. It turns out they're a little more available than I thought they were. I wound up buying them from Terry's Jaguar. The part number is JLM442.
TreVoRTasmin
Feb 23, 2021 03:13 PM
Johnken
Apr 8, 2018 10:21 AM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
