Why No Gears On B/W 12?
Old May 8, 2012 | 08:39 AM
costatropical's Avatar
Default Why No Gears On B/W 12?
Have just started to re-commission a 1977 V12 Series 2
Coupé. The engine is now up and running, but needs a bit
of TLC, but the auto box was N/O, which it was before
being left dry stored for around 8 years. The dipstick was
showing less than min, so put in 1/2 litre of Dexron &
still low so put in another 1/2 litre, and now above max.
Problem is I thought putting in the missing fluid level
would solve the problem, but obviously not! It functioned
A1 before, what has caused the N/O of the box?
Old May 8, 2012 | 04:24 PM
Fraser Mitchell's Avatar
Torque converter, maybe ? If this passes no drive from the engine, you'll have no gears. I assume from your post, there is nothing, even reverse.
Old May 9, 2012 | 12:15 AM
Thx Fraser, no there's nothing happening in any gear, even with foot on the brake a revving slightly!
Old May 9, 2012 | 03:44 AM
Has someone pinched the prop shaft?
As per Fraser.
But check the shifter to box couplings.
Old May 9, 2012 | 06:37 AM
Why are props expensive/rare😜. Not checked shifter to box couplings as still peed off😢. Thx Dave.
JaguarLover101
48
Jun 12, 2023 10:28 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
ziondio
Sep 29, 2015 01:58 PM
