Widest tire i can fit?
Old Jan 25, 2016 | 11:19 PM
sunchip's Avatar
Default Widest tire i can fit?
Hi there!
quick question, what is the widest tire i can fit on the car? the back has about a 2 inch fender flare and the front is stock. the rims have an offset of +20 and -6 front and rear and are 15x7 all around. I was thinking of a 235/60/15 in the front and a 245/60/15 rear? would that theoretically work?
Old Jan 27, 2016 | 08:55 AM
NathanDD6's Avatar
Widest tyre on standard rims was 235 if I'm correct.
Old Jan 27, 2016 | 05:05 PM
ronbros's Avatar
run on rears 295-35-18,, frt 275-35-18.
works for me!
Old Jan 27, 2016 | 08:43 PM
sunchip's Avatar
im going to go ahead with the sizes i thought would fit and report back here
Old Jan 29, 2016 | 12:15 AM
Mr.Hotrod's Avatar
I can tell you that I've run a 315/30/18 Goodyear on the back of my car, but they will curiously rub the inside sidewall when the suspension compresses. Although on a smooth curvy road the holding and ride was phenomenal.
Old Jan 29, 2016 | 09:24 AM
icsamerica's Avatar
works for me!
What exact car...no way a 295 is fitting the rear of a sedan with out modifications.
Old Jan 29, 2016 | 09:28 AM
icsamerica's Avatar
A tire with an 11.5 inch section with on a sedan? No surprise it rubs.
Old Jan 29, 2016 | 10:40 AM
Mr.Hotrod's Avatar
In all fairness the question asked the widest tire one could run. Assuming the roads one runs on aren't terrible those tires were not hard to run. It took quite the jolt to make them rub. If they fixed the roads here in Indiana I would run them again.
Old Jan 30, 2016 | 06:48 PM
sunchip's Avatar
I dont want to run a crazy wide tire in the back, it is only a 15x7 spaced out 1.25 inches, 245/255 is the widest i think ill go
Old Jan 30, 2016 | 08:45 PM
icsamerica's Avatar
A wider tires needs a wider rim and with a 7 inch rim i'd run nothing more than a 225. If the rim is too narrow for the tire it creates un-predicible and loose handling. So the question should be...Whats the widest tire I can run with a 7 inch rim.
Old Jan 30, 2016 | 10:28 PM
anjum's Avatar
Gordian Knot solution!!
Old Jan 31, 2016 | 10:18 AM
ronbros's Avatar
no rub as far as i can tell, altho camber is a bit much on hard acelleration!
pic enclosed.
Attached Thumbnails Widest tire i can fit?-jag-rodstr-001.jpg   Widest tire i can fit?-jag-rodstr-002.jpg
Sarc
XJ40 ( XJ81 )
Feb 13, 2016 07:26 PM
kmmoore1013
Feb 2, 2016 06:46 PM
kreyszig
Jan 29, 2016 03:37 AM
johndahlheimer
XE ( X760 )
Jan 26, 2016 05:20 PM
stephensd1
Jan 26, 2016 03:10 AM
