Window motor/regulator
Old Apr 8, 2017 | 03:53 AM
Blackbeard911's Avatar
Default Window motor/regulator
My fellow Jag Lovers,
I am wondering where I could find a window motor/regulator for my series 1 XJ6? My front passenger window will no longer roll up or down. I think age has caught up with it. Any help would be great! Thanks.
Old Apr 8, 2017 | 04:11 AM
Jose's Avatar
I think Jaguar sourced those motors from General Motors, Chevy / Buick / Pontiac of the period. At least they are GM in the Series 3 XJ.
another option is to remove it and take it to an electrical motor shop to see if it can be repaired. You will have to remove it anyway, so start there.
I would get a bright light and a camera in there to take pictures or video before removing or undoing anything, to have a reference.
Old Apr 8, 2017 | 06:31 AM
Robert Laughton's Avatar
Try Dave Boger at EverydayXJ.com
If he doesn't have one, I do, but I'm far away in Canada,
Good luck,
Rob
Old Apr 8, 2017 | 09:22 AM
JagCad's Avatar
Before you absolutely convict the motor and regulator, open the console and remove and clean all the switches. A far easier task with an excellent chance of fixing the window.
Carl
Old Apr 8, 2017 | 09:46 AM
Roger Mabry's Avatar
S1 window switches are not like the later cars.. get a couple of spares.. first substitute the failing front window switch for one of the rear ones (they get less use)... then you will know for sure... also the window motors are different...
Old Apr 8, 2017 | 11:25 AM
Thanks for all the information gents! I looked on the site recommended and there's one for sale! Christmas came early I will be purchasing it and also having my old one checked out to have a spare as suggested. Thanks again!!!
Old Apr 8, 2017 | 06:22 PM
itchyback's Avatar
hey,
I have two motors that werent working. I took them apart and cleaned the commutator and brushes with a scotch bright pad. I also cleaned the metal case and commutator and rotor coils with brake cleaner (acetone). it started working then easiest fix ever. its pretty easy to take apart and put back together, just take a picture of the spring before taking it apart so you know how to put it back together.
Also take a picture of how the wires are stuck together and share it with me. i'm trying to install power windows in my car and i think i have all the bits but dont know how all the wires connect.
Old Apr 8, 2017 | 10:06 PM
Default S1 window wiring
Hopefully this will help with your window wiring... the last photo is the control box located in the drivers side kick panel on the outside of the car.
Attached Thumbnails Window motor/regulator-drivers-switch-wiring.jpg   Window motor/regulator-schematic.jpeg   Window motor/regulator-window-control-box.jpeg   Window motor/regulator-imag2122.jpg
Old Apr 8, 2017 | 11:09 PM
Gents, thank you all again. The support and info I've received is why I love this forum!
Old Apr 8, 2017 | 11:35 PM
itchyback's Avatar
thanks roger, i'm also needing a picture of how the wires and motors and switchers are connected in the front and rear doors.
Old Apr 9, 2017 | 06:58 PM
Motors just have the one connector on the bottoms and the Black ground wire... colors of the wires for all the window switches are on the schematic I attached on the post above.
I never took any photos of the motor wiring inside the door... do have a photo of the regulator when I put on a new bearing to fix a worn out regulator. Finding parts for these very old cars is becoming a huge problem.
Attached Thumbnails Window motor/regulator-drivers-window-regulator-arm-bearing.jpg   Window motor/regulator-drivers-window-regulator-arm-bearing-002.jpg
