Window rolls down but not up
Old Dec 22, 2016 | 04:58 PM
Fraser Mitchell's Avatar
Are you getting enough volts to the motors ? What voltage is the battery and what is the voltage when the engine is running ? There could also be an earth problem that will produce the same results.
Old Dec 25, 2016 | 08:40 PM
BuzzysJag's Avatar
Default It's the window tracks
I took the motor and arm out and tried just moving the window up and down in its track. It gets stuck. The rubber tracks are shot. Not salvageable. Anyone know the best place to get the rubber for these tracks?
Old Dec 26, 2016 | 02:48 PM
Jose's Avatar
try a junkyard, Buicks, Pontiacs, Cadillacs, the higher GM cars from the 1980's. the window motors are GM also.
Old Mar 29, 2024 | 04:04 PM
CB3's Avatar
CB3
Gregory,
THX - Perfect solution, just used some CRC Electrics Spray Cleaner on my driver's (LHD) window switch, presto working like new!
Never panic, work the problem, consult the formum, then retain the knowledge!
Cheers,
Chuck
Caretaker 1982 XJ6 S3
Jagvirgin
Aug 13, 2011 10:12 PM
