Wire I'd (ez one I think)
Old Dec 13, 2015 | 09:17 AM
Calhale's Avatar
Default Wire Id (ez one I think)
My labal fell off this wire, does anyone know where it should go? It's on the harness that (with another connector) connects to the temp sensor on the rail. Seems to be white, which typically means +12v...
Old Dec 13, 2015 | 09:38 AM
JagCad's Avatar
Clue:
White means hot when ignition switch on. Accessory, run and crank.
Carl
Old Dec 13, 2015 | 11:04 AM
Doug's Avatar
Probably goes to the coil "+" post....or to the ballast resistor if you have one
A couple of the relays on the firewall have a white wire as well.
Old Dec 14, 2015 | 03:52 PM
Calhale's Avatar
Thanks DD!
I'm betting it doesn't run back to the FW, as it's sourcing from there (that's where that 3 prong connector comes from *I THINK*). I've got a beater over at the local Jagguy I can go look at -- though mostly it's got crazy bad wiring, I think this one is solid.
jal1234
Nov 11, 2018 06:20 PM
JonnieMorgan
20
Apr 29, 2016 07:12 AM
Valium.Skies
Dec 14, 2015 11:27 PM
Joshua Brent Langford
Dec 9, 2015 07:00 AM
Megawatt
Dec 9, 2015 01:56 AM
