XJ12 Diff ratio change
Old Apr 8, 2016 | 02:45 PM
Johanvandoorne's Avatar
Default XJ12 Diff ratio change
Dear Friends,
I want to know if it is possible to change only the gear ratio in a xj12 diff.
My current ratio is 3.31 and want to change the ratio to 3.54 ( keeping the diff lock )
my idea is changing only the ring gear and pignon, or maybe other ideas ???
Old Apr 8, 2016 | 02:59 PM
icsamerica's Avatar
3.31 to 3.54 is just a small jump I dont think it would be noticeable, especially on a v12.
Not easy to do. Not low cost to do right...the ring can modified but the pinion is different.
You need a the dana 44 to Jag flange and a diffrent seal
DANA SPICER 2-1-1881X companion flange fits all Dana 44 front or rear with 26 spline pinion
Here are some detailed diffrences
Jaguar salisbury/dana 44 gear swap conversion kits???? | The H.A.M.B.
Old Apr 11, 2016 | 08:54 AM
lickahotskillet's Avatar
Default 3:54
johan,
I switched from a 3:31 to a 3:54. I shorten the route by buying a center section from Coventry West. Spoke with Dick Maury. "Shortened the route" is a misnomer, as I freshened everything else.
Ahead of the 3:54 is a 700R4. Makes a nice combination in my case. The 12 & T400 were good or 11 MPG. The new combination with a BBC gets 14 MPG if I keep my foot out of it.
At times, I wish I had went to the to a 3:90 - quicker in the city and the 1/8 mile.
Old Apr 11, 2016 | 10:12 AM
ronbros's Avatar
Originally Posted by lickahotskillet
johan,
i have a 3.73 ratio in my XJS, also went to 700R4, makes great acceleration and cruising, in OD ratio is 2.60-1. best of both worlds.
iceempror
Aug 8, 2024 04:10 AM
Harry Dredge
Apr 14, 2016 04:19 PM
Beavis
Apr 8, 2016 03:08 PM
tdyer
Apr 8, 2016 07:09 AM
fastlanz
Apr 7, 2016 09:13 PM
