xj12c miss
Old Nov 9, 2011 | 11:33 AM
pak308's Avatar
Default xj12c miss
i have a question ....i have a miss on the right side of my v12 . i did a compression test , checked the injectors , power to the injectors, made sure i had spark to the plugs. im stuck on what to check next .... any suggestions ?
my second question is .... is it possible to strip all the polution control crap off the engine with out hurting the engine or the vaule of the car ?
Old Nov 9, 2011 | 01:47 PM
Sean B's Avatar
I'd do what you suggest, in fact I'd go the whole hog and install fuel injection from an XJS, and dump all that emissions junk. That would certainly add to it's value, not devalue it, and improved throttle response, fuel economy and performance - in fact it opens up a whole new world of possibilities ;-)
Old Nov 9, 2011 | 02:09 PM
Doug's Avatar
Checked the injectors....how?
Old Nov 9, 2011 | 02:14 PM
Sean B's Avatar
missed that bit!
Old Nov 9, 2011 | 04:17 PM
pak308's Avatar
what about the air injection rail ... if i pull that is there a way to plug all the holes or somthing i can buy to plug them ? as for the injectors i pulled them, and tested them ...then atfer i put them back used my meter to see if power was making it to the injetors.
Old Nov 9, 2011 | 04:27 PM
Per's Avatar
Per
Any change between hot and cold? If OK initially I'd suspect the ignition amp. If it is an original Opus it is way past its best. As a stop gap solution you could open the box and replace the electrolytic capacitors but the permanent cure is new internals (ReOpus from NZ or new box from I think SNG Barratt or one of the others).
Some aftermarket dizzy caps are bad even when looking perfectly good, same for rotors.
Check with a stethoscope (mechanics' rod type) that the clicking sound from the injectors are similar.
Finally you could have an intermittent ignition or injection fault due to fried wiring in the engine valley.
Old Nov 10, 2011 | 05:28 PM
pak308's Avatar
ok i will check the electrolytic capacitors as soon as i can .... thank you so much for the info guys !!!
Old Nov 14, 2011 | 09:48 PM
pak308's Avatar
is it possable to remove the air injector rail ? will the car run with out it ?
Old Nov 15, 2011 | 08:33 AM
Per's Avatar
Per
Yes as long as you plug the holes in the manifold airtight. The sole purpose is to introduce extra air to burn unburnt hydrocarbons aka pollution.
Old Nov 15, 2011 | 07:08 PM
pak308's Avatar
ok i have news today i had my opus ignition amp thingy checked and the main compacitor was bad . its a 0.002mf 600v plus i found a place to buy a repus here in the US its about $424.95 if anyone is looking for one the phone number is 1-800-444-5247 i talked to a guy named John in parts department
Old Nov 16, 2011 | 08:29 PM
pak308's Avatar
ok i put the new compacitor in the ign amp box had it checked out again . reinstalled it back in the car and still have the miss . whats the next thing i need to chase down ?
Old Nov 17, 2011 | 06:41 AM
Per's Avatar
Per
Start by standing at the rear and hold your hands about 20cm from the exhaust engine running. Feel for an uneven beat.
Check the coil to cap lead with an ignition lamp just illuminating a dark surface and preferably at dusk. If no obvious miss try one plug lead at a time and note your findings.
Get back to us with the results.
NS2000XKR
Jan 1, 2017 10:41 AM
hoodun
Oct 6, 2015 08:34 PM
millertic
Sep 30, 2015 08:11 PM
blackenedindustries
Sep 30, 2015 10:17 AM
