XJ2 S2 distributor
Old Mar 19, 2025 | 11:53 PM
xjtom's Avatar
Default XJ2 S2 distributor
Hi, looking for information on a lucas 45d6 distributor total advance include vacuum, 4.2 ltr low comp/ i know all the general ignition timing - static - central & vacuum but not total @ what rpm…info is generally 8 Btdc - 20deg @ 1700 rpm, any links or info helpful… thanks
Old Mar 20, 2025 | 12:52 AM
Jagboi64's Avatar
If you disassemble the distributor to see the weights, there is a number stamped on the weight, that is the total mechanical advance. There can be different weights for different markets.
Old Mar 20, 2025 | 03:37 AM
xjtom's Avatar
Default XJ6 S2 Lucas 45D6
i know the central weight advance is 13Deg and vacuum is 14Deg, what i'm trying to find out is at what rpm is total advance including static deg?
Old Mar 20, 2025 | 11:31 AM
Jagboi64's Avatar
From what I can determine, that is dependent on the springs. You would need to find a Lucas handbook that lists the spec number that is stamped on the distributor and see what it says. For example, in the earlier 22D6 distributors used on E Types apparently there are 338 possible combinations! Unfortunately I don't have a Lucas book that lists any of that data.
As a very rough rule of thumb, I would expect the total advance to be all in by 3000-3500 rpm.
Old Mar 20, 2025 | 09:44 PM
David84XJ6's Avatar
1984 XJ6 S3 4.2 low compression
Overhauled Distributor 1984 XJ6 Calif LU 41912A
Adjust Air gap on Pickup to: .008 to .014 inches with non-metallic feeler gauge
Centrifugal advance Max (2 x 10* = 20*) + 17* = 37* at crank shaft
Vacuum advance Starts @ “Hg Max Adv (Dist. Degrees) @ “Hg.) initial Timing
#1703 4”8”8* .....4” 8* 8” (8* at distributor, 16* at crankshaft)
#1504 4”9”6* .....4” 6* 9” (6* at distributor, 12* at crankshaft)
Initial Timing (17*) = 17* @ 800 RPM (TB vac capped off)
WOT (17*+ 2x10*) = 37* @ 4600 RPM
Cruise (17*+ 2x8*) = 33* @ 3000 RPM (Timing Set point) (no Vac Advance at this RPM under cruise)
Rgds
David
xjtom
General Tech Help
Oct 26, 2023 04:52 PM
iramphal
Jun 13, 2020 06:46 AM
Terry S Martin
E type ( XK-E )
Apr 3, 2020 07:53 PM
yachtmanbuttson
Jul 1, 2018 11:01 AM
