XJ6 4.2 Leaking oil at rear of block above bellhousing
I've been trying to stop the oil leaks for years now on this car. Replaced the cam feed banjos and copper washers, sealed up the cam covers. I suspect now that the "blanking plate" on the back of the block is leaking. It has 5 or 6 7/16 bolts and it is trapezoidal in shape. Does this lead to an oil passage, or coolant? It is very oily, and the cam oil feed lines are dry, so I suspect it to be the problem. The oil is pooling on top of the bellhousing and running down all over the engine and trans.
Is it possible to change the gasket with the engine in the car?
That plate covers a casting hole to the coolant passages. For the life of me I can't see how you can possibly get oil leaking out if the gasket for this has failed. Surely the oil is dripping down from one of the camshaft oil feed banjos, or there is a very small hole in the copper pipe near those ? Of course, as 'slofut' says, one of the tapped holes for the securing screws may be deep enough to enter one of the oil return passages at the back of the head. This is easily sealed up with some plumbers PTFE sealing tape. Take out one of the suspected bolts and see if there is oil on the threads. If you find one with this then you know the tapped hole has broken through there. The PT0FE tape will seal it up for good. The oil in these passages is not under any pressure at all, it is oil draining back into the sump via the block.
