XJ6 4.2 Series 2 1978 fuel pump
Old Oct 25, 2019 | 09:24 AM
Gacco's Avatar
Default XJ6 4.2 Series 2 1978 fuel pump
Anybody who can tell me where the fuel pums are located? I look everywhere but can't find them. They are not in the trunk, can't be seen aunt the body, only have one tube coming out of the tank. No wiring.
I did however find the wiring inside the trunk on both sides, white green-purple green- however no pumps has bee found so far.
javascript:;if found a picture on eBay showing the pump, outlet and the wiering- however I don't have any connectors comming out of the thank by the outlet.
Alt1.
https://www.ebay.com/itm/JAGUAR-DAIM...MAAMXQVERS4QDp
Alt 2.
https://www.ebay.com/itm/FOR-JAGUAR-...0AAOSwAj5Z0jgS
So where are they?? Anybody?
Old Oct 25, 2019 | 08:39 PM
Nic Graves's Avatar
Alt1.
Alt 2.
They are inside the fuel tanks remove the cover at the rear or the rear wheel and you will find the sender unit and fuel pump. Disconnect your battery and Drain your fuel tank before removing the sender unit.
AlinBC
XJ40 ( XJ81 )
Jul 11, 2019 07:45 AM
iflytb9
Nov 27, 2016 12:53 AM
John Gloyd
Feb 25, 2016 05:13 PM
dougripley
E type ( XK-E )
Aug 20, 2015 05:37 PM
alabbasi
Nov 17, 2013 03:28 AM
