XJ6 s2 paint code.
Old Jun 17, 2013 | 10:05 PM
MJG's Avatar
MJG
Default XJ6 s2 paint code.
Hi all,
I know this topic has been done to death but I am having trouble IDing my paint colour.
I have found the dog tag on the LH rear of the car under the rear bumper.
It has the following code
E 050151
I cant seem to find a reference to this number anywhere. This is an Australian delivered car if that makes any difference.
Thanks again
Old Jun 18, 2013 | 02:24 AM
Assuming teh Yellow beast in teh picture??.
I will look thru the paint code decifer software at work tomorrow, and see what I can find and post back tomorrow night.
Meantime I will try and stir the memory as to what that colour was called in the real world, Cannery Yellow comes to mind???.
Old Jun 18, 2013 | 02:58 AM
MJG's Avatar
MJG
HI Grant
Yes the yellow beast.
Thanks for you help. Will be interesting what you come up with.
Old Jun 19, 2013 | 03:45 AM
OK, as promised, I remembered to do what I said, scary.
That code you gave means nothing to our system, surprised, NO.
A search using "Yellow", for Jaguar came up with the following:
Cotswald Yellow (79-80) D31818 212/FDE.
Yellow Gold (77) D30398
The years in brackets are vague on this system at best, so I generally ignore them.
I reckon that colour in the snap is Cotswald Yellow, but I have only seen one other S2 in that colour and that was a 1977 build date.
Hope that helps some.
Old Sep 23, 2013 | 01:54 AM
DJG's Avatar
DJG
Hi MJG
I'm not sure if you've found your colour match but if the yellow on your car has a green tinge to it in certain light it may be the Jag colour "Green Sand".
I have a '73 model in this colour and when I saw the the pic's of your car I thought it was the same.
I noticed you have done the chev conversion. How do you like it and have you run into any over heating at all?
Old Oct 1, 2013 | 11:52 PM
Napoleon Solo's Avatar
Default Paint code
Hello,
If your car is a 73/74 SII then the code is definitely ' green sand ' . As far as I know, that paint colour was discontinued after 74 but the odd 75 straggler may have been sprayed. My car was an Australian delivered car too - apparently only 2 in WA were delivered in that colour. I took mine back home to Canada when I left but I did see the other one from a distance on the freeway. I lived in Perth.
Attached Thumbnails XJ6 s2 paint code.-100_0114.jpg   XJ6 s2 paint code.-dcfc0011.jpg   XJ6 s2 paint code.-dcfc0018.jpg   XJ6 s2 paint code.-dsc04621.jpg
Old Oct 4, 2013 | 06:22 AM
DJG's Avatar
DJG
Hi Napoleon
The original posters car is a 77 model. It is my car that is a 73 model and is painted green sand. I did a bit more research after my post above and found a link to the paint codes and as you say, the green sand colour was only available in 73/74. So it looks like MJ's car is a later model yellow.
I like your car by the way. I think it's a great colour on Jags.
Darren
Harry Dredge
Oct 4, 2024 05:37 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
Don Elliott
Sep 2, 2015 09:38 AM
hatajay
Nov 30, 2009 03:46 AM
bhmaxjag
Oct 23, 2009 06:22 PM
